Old 02-26-2023, 09:14 AM
wakesupremo wakesupremo is offline
Default Torque converter to flex plate bolts
I am having a problem fitting new ARP bolts, Does it matter whether they go in from between flex plate and engine block with the nut on the transmission side or with the bolt head the transmission side and the nut between flex plate and engine block?
Old 02-26-2023, 09:41 AM
Naw, but there is forthought to put the nut on the softer-metal side, and the SHOULDERED bolt on the hard metal FLEXPLATE side.
Space the converter off the Front pump!, Grind the bolt length to ~ 2 threads after tightened.
Old 02-26-2023, 07:09 PM
Schurkey Schurkey is offline
Am I missing something? Shouldn't a Pontiac torque converter have welded-on spacers that are drilled and tapped? No nuts involved.
Old 02-26-2023, 07:37 PM
Must be after market hi-po converter?
Old 02-26-2023, 09:51 PM
Nuts and bolts is Surely not an original TH400 converter.
Old 02-26-2023, 10:10 PM
Or an original CHEVY converter, which doesn't clear the balance weight(s) on the flexplate.
Am I wrong? Chevys used nut-and-bolt fasteners, Pontiac, Olds, Buick, Cadillac used bolts into drilled-tapped standoffs welded to the converter.
Old 02-27-2023, 02:59 AM
Thanks once again for the replys. Its a TCI Saturday night special. Never had any issues and have been using it for many many years. I don't recall ever having a converter with captive nuts or welded on threads.
Old 02-27-2023, 09:04 AM
All GM stock muscle 12" & 13" seemed to have welded nuts. 3 or 6.
The tiny 9", 10", GMs may have used loose nut& bolt.
11" cores?
Old 02-27-2023, 12:05 PM
My after market 9" converter has welded on nut. Went to put in original bolts and found converter was metric.
Old 02-27-2023, 05:05 PM
Most all of mine use nuts and bolts. Grade 8s.
Old 02-28-2023, 11:42 AM
1969GiPper 1969GiPper is offline
11" cores?
I have a GM converter that has 6-welded on lugs with standard threads. Has GM part number 8625982 stenciled on it. It’s often referred to as the Chevy “L88” converter. Never saw a factory installed 6-lug converter in a Pontiac.
