Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Offy Dual Quad 5499 all original and in great condition, I'm not sure it was every used. $400 shipped
Torker 2 - New 100% original comes with original Edelbrock throttle bracket and hardware. $350 shipped Pro Comp EFI intake - New $175 shipped. I have a new Performer RPM and an original 66 tri power intake coming too but I haven't got them dug out of the garage for pics yet. Feel free to PM me with any questions. |
I would be interested in the performer rpm when it's available.
I’ll take 2nd slot on rpm. Is the tripower original or aluminum aftermarket?
I;ll get inline for the tri-power...
Are 66 and 65 tri-power intakes interchangeable? Or do you need an adapter for the middle carb flange?
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
I will get the RPM intake dug out today. It is still in the original box. Same price as the T2 $350.
The tri power is an original 66. BUT the coolant crossover was cracked and has been welded around the temp sensor. It would be good for someone who has a separated coolant crossover or the temp sensor hole will need to be redrilled and taped. It will be a couple days before I can get it dug out to get pics. |
Here is a pic of the RPM intake for those interested.
The Following User Says Thank You to Kevin For This Useful Post: | ||
I'm interested in your rpm manifold and sent to a private message. Thanks
I'm out on the original tri-power... thanks
Hey Kevin ,I'll take the performer rpm. How do you want to get paid.
Here is a pic of the tri power intake. It needs some TLC. The right side temp sensor port has been welded and needs drilled and tapped. One carb stud hole in the center pad needs to be repaired as well. Asking $100 + shipping.
PM sent about tripower intake
Tri Power intake is gone. The others are still available. I'm open to offers.
