Is it possible to remove the textured coating from these moldings? Thinking of getting rid of my top and go to painted. Would i need to find new moldings?
Are you planning to go with a 2 tone paint? Or just a smooth top single color? If you are going to stay with 1 color and just remove the vinyl top you don't need the trim just remove the fasteners and fill the holes.
I suspect you will have to do alot of filling and sanding to the metal under the vinyl anyway. If the trim pieces are metal I would think you could strip off the coating. I have not owned a mid 70's car with a vinyl top in over 25 years so I do not remember if the trim pieces are metal, plastic, or a combination of both.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
