Old 12-31-2022, 04:23 AM
elefantrider's Avatar
elefantrider elefantrider is offline
'63 Auto Transaxle complete, drum to drum. Out of a driving California car. Stored indoors. $600
  #322
Old 03-17-2023, 01:12 PM
tekuhn tekuhn is offline
Default Complete Powertrain and Suspension For Sale
I have the complete drivetrain that I pulled from my '63 Tempest for sale. It is everything removed from a reliable running/driving car. It includes:
- '61 DS code engine. Professionally rebuilt. I'm guessing less than 1000 miles ago. Pistons replaced with flat-tops - so it is now a 10+ CR. Camshaft reground by Effingham Machine to 4-bbl specs. Starts and runs great. Pertronix module in the distributor. I have paperwork documenting work. Includes bellhousing and clutch. Clutch needs to be replaced. Rear main seems to have a small leak.
- Entire rear suspension w/ 3-speed manual transaxle. Shifted and drove great. 2nd and 3rd synchros good - has leaks. Unknown year or gear ratio. Will look at numbers if you tell me what to look for. Includes shifter. Handle was cut off and Hurst welded on below boot. I have the original if wanted. Shifting was sloppy, but appears to be wallowed-out pin where shift tube connects to transaxle rod.
- Complete front suspension. Was rebuilt as needed and was tight and brakes worked well. Will include steering box if wanted, but shaft was cut near firewall.
- Drive shaft and housing. The shaft bearing sounds are noticeable when the clutch is engaged in neutral. Assume they should be replaced, but have never heard another car to know what is normal.
Everything is located in East Texas - ZIP 75757. I will assist in packaging within reason, but you will need to arrange shipping on your dime. These are heavy and long items. Oil will be drained from engine, trans/diff.
Price is $2,750. PM me if interested. I prefer not to separate these parts, but might consider reasonable offers.
ID:	608986   Click image for larger version
ID:	608987   Click image for larger version
ID:	608988   Click image for larger version
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
  #323
Old 03-18-2023, 09:51 AM
Default Grant Walnut Steering Wheel Kit For Sale
Grant Classic Nostalgia Series 15" walnut steering wheel kit. Purchased from Ames Performance, this is the complete kit for '61 thru '63 Tempest and LeMans. Part # LA185. Current retail price is $239.00. Kit includes all pieces in the pictures - steering wheel, mounting hub, turn signal cancel cam, lower trim piece, horn spring contact, horn contact, horn contact cover with Pontiac arrowhead logo.
The walnut is in excellent condition with no cracks or separations. The brown stain is rubbed lighter in places, but the wood is unsealed and would accept new stain nicely. I considered restaining it myself but decided to allow the purchaser to stain it the shade of their choice. It is also quite attractive as-is.
This is a universal steering wheel, and will fit other vehicles, but may require different mounting hub and trim.
Located in East Texas - 75757. Asking $125.00. Will ship for actual cost.
ID:	609032   Click image for larger version
ID:	609034   Click image for larger version
ID:	609035   Click image for larger version
ID:	609037   Click image for larger version
  #324
Old 03-18-2023, 01:35 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
How much to ship to MN 56401?
  #325
Old 03-18-2023, 04:55 PM
I'm assuming you're asking about the steering wheel and not the drivetrain .
FedEx Home service is $24.85. I'm guessing I can ship it a little cheaper using USPS First Class - so I'll go out on a limb and agree to ship it for $20...
  #326
Old 03-19-2023, 12:16 PM
hobbygto65's Avatar
Do you do paypal?
  #327
Old 03-19-2023, 01:02 PM
Yes, no problem. PM me for details.
  #328
Old 03-19-2023, 03:48 PM
hobbygto65's Avatar
Pm sent
  #329
Old 03-19-2023, 08:40 PM
***** SOLD *****
  #330
Old 03-23-2023, 11:44 AM
'63 Auto Transaxle complete, drum to drum. Out of a driving California car. Stored indoors. $400
  #331
Old 03-23-2023, 11:46 AM
'63 Lemans/Temest front fenders.. No rust, indoor stored. $500.
  #332
Old 03-31-2023, 05:26 PM
TRMarrr TRMarrr is offline
Location ?
  #333
Old 03-31-2023, 05:28 PM
Location ?
  #334
Old 03-31-2023, 05:59 PM
Originally Posted by TRMarrr View Post
Location ?
If I’m not mistaken he keeps his parts in Northridge CA. I’ve been there once before.
  #335
Old 04-01-2023, 10:40 AM
That's correct, specifically Northridge in Southern California like it says in the upper right hand corner of my ad. Cheers B-man, been a long time!
The Following User Says Thank You to elefantrider For This Useful Post:
  #336
Old 06-28-2023, 03:29 PM
Halfthrottle Halfthrottle is offline
Default 63 Coupe door panel carpet set black
I have a set of Black door panel carpets. I removed them from my white panels to have saddle carpets installed. They were just glued in place. Make me an offer keeping in mind it will be about 10$ to ship them.
  #337
Old 07-04-2023, 12:46 AM
ronnyhotrod ronnyhotrod is offline
Default 1962 insterments
Originally Posted by mechanickeith View Post
61-62 instrument cluster assy , shows 33,583 miles. took out of a wrecked car, everything worked when pulled. $25 bucks plus shipping.
61-62 Tempest4 banger complete clutch assy, Flywheel resurfaced, New pressure plate, disk & release bearing. Make offer, Shipping would be a killer. Without the flywheel, this kit is well over $100 dollars.
177 head, magged, cleaned, resurfaced, new valves & springs, painted, ready to bolt on. $150.00. Have more than that in it in parts. Shipping extra
Im looking for the gauge bezel pod that sets on the dash and the instruments fit in it
  #338
Old 07-04-2023, 12:53 AM
Default instrument pod
NTB 1962 Instrument pod from top of the dash
  #339
Old 09-21-2023, 09:40 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 1963 Tempest / Lemans Factory A/C right side kick panel
I have a left over A/C kick panel, I had a dozen made for Little Indians club members a while back. These tend to break or are missing. This is made by a 3D printer so it will be here longer than you or I.
$150 shipped
ID:	620325   Click image for larger version
  #340
Old 09-21-2023, 10:22 PM
Sanduners's Avatar
Default 1963 Dash panels
I have a couple dash panels, these can be painted to match your car. Both in great condition.
$35 plus shipping
ID:	620331   Click image for larger version
