Old 03-24-2023, 12:53 PM
Default Hole in the hood or hole in the head?
I'm curious as to how the 68/69 crew feels about cutting that big hole in a good hood for a hood tach.
Now, I know that the standard answer that always comes back is- "It's your car, do what you like" and there's nothing wrong with that answer except that that is not the question. How do you feel about it?
Old 03-24-2023, 01:11 PM
It is reversible, so if you wish to have a hood tach go forward.
Old 03-24-2023, 01:15 PM
tinindian68's Avatar
tinindian68 tinindian68 is offline
It’ll make your GTO even cooler. Cut the hole!
The Following User Says Thank You to tinindian68 For This Useful Post:
Old 03-24-2023, 01:22 PM
ts3189's Avatar
ts3189 ts3189 is online now
I never once have regretted it!
The Following User Says Thank You to ts3189 For This Useful Post:
Old 03-24-2023, 02:55 PM
My in-dash tach took a dump quite a few years ago and I really miss having a tachometer in just about any kind of car, but especially this one. Even though I wasn't actively shopping for one I ran across a pretty good deal on a hood-tach and bought it. Then the doubt started creeping in....
I just finished wiring it under the hood to see if it worked and it's perfect. Then I come back here and see these replies and I'm getting a little stoked... I guess a hole saw is in my future!
Old 03-24-2023, 03:53 PM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
Greg Reid my only input to this is...... post up some pics when she's done !!
NEVER DRINK DOWN STREAM FROM THE HERD
The Following User Says Thank You to HO LEMANS For This Useful Post:
Old 03-24-2023, 04:01 PM
She'll be even lighter!
Old 03-24-2023, 04:02 PM
Haha, will do HO LEMANS!
The biggest challenge for me will be getting it painted without too much orange peel. Being a relatively small job I'm considering using an airbrush. Gotta play around with some test panels.
Old 03-24-2023, 07:32 PM
ts3189's Avatar
Use a punch out tool easier and cleaner
Old 03-24-2023, 08:25 PM
I've used them before but don't have one. I'll bet a good three and a half inch one is pretty expensive. Also, the placement of the hole has it coming through a fair bit of the bracing. Will a punch out tool stay straight going through the multiple layers on one side of the hole only?
Old 03-24-2023, 09:57 PM
Just get the Hood Tach 1st, then cut the hood. And perhaps a Dash Clock. You are gonna want that.
Old 03-24-2023, 11:07 PM
Well, I have the hood tach already and yeah, at some point I'll replace the blown dash tach with a clock. I'm in no hurry to pull the instrument panel though.
I wired the underhood harness today so l'm committed to doing it. When I get it painted to my satisfaction I'll cut the hole.
Old 03-25-2023, 02:53 AM
I used to be able to remove/swap the Dash Clock ( or Dash Tach ) by using a 1/4" nut Driver, without removing any Dash stuff.
Certainly remove the Lower AC vent system if it were there.
My last effort with installing the Dash Tach was tedious to do such. Think i removed DashPad to properly R&R the 2 upper 1/4" screws.
Old 03-25-2023, 03:10 AM
1965gp 1965gp is offline
Do it. Too cool not to.
The Following User Says Thank You to 1965gp For This Useful Post:
Old 03-25-2023, 10:41 AM
kk68's Avatar
kk68 kk68 is offline
Go for it…no regrets adding one to mine. Here’s a few pics of my install. Mine wasn’t as nerve racking since my hood still needs painting.
ID:	609652   Click image for larger version
ID:	609653   Click image for larger version
ID:	609654   Click image for larger version
ID:	609655   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
The Following 2 Users Say Thank You to kk68 For This Useful Post:
Old 03-25-2023, 01:04 PM
Thanks kk68. Those pics are helpful. I'm using the template provided with the tach and it puts the center of the hole 13" from the back edge of the hood. 3/8" closer than yours and I guess that's close enough but it looks to me that you barely had to touch that hood bracing when you cut your hole. Mine appears to be taking quite a lot more from just eyeballing it. That's a concern because I don't want to have to cut through any more of that bracing than I have to.
In fact, as close as I can tell, the front edge of that bracing is going to wind up almost at the center line of my 3.75" hole! Right about where the threaded studs are. I think I need to move it up 3/8 to 1/2" to be closer to where you are.
Also, that 2* offset isn't mentioned. If anything, looking at my pattern it seems to be offset about the same amount but in the opposite direction.
Sent from my moto g stylus (2021) using Tapatalk
Old 03-25-2023, 08:58 PM
kk68's Avatar
I did a lot of research on locating the proper size and spot for the hole and settled on the location from prior post. This is an old photo I found that showed the factory location from the underside of the hood with minimal cut into the bracing…very close to where I ended up.
68 GTO convertible
C1 224 Triple white
Old 03-25-2023, 10:29 PM
Red Box Rebel Red Box Rebel is offline
The Hood tach is worth it and just make sure you use the correct Template and put the hole in the correct place.
The Following User Says Thank You to Red Box Rebel For This Useful Post:
Old 03-25-2023, 11:56 PM
I'm comfortable with the location now... I moved my pattern forward about half an inch and looked at it carefully from the side with one of those little antenna magnets stuck to the front edge of the brace. That gave me a visual marker from the side where I could see my pattern and the little antenna hanging down from the bottom of the hood at the same time.
I think it's going to wind up in just about the same place as that photo you just posted.
I'm definitely not cutting anything until I can get the paint right. I don't want it to look like an add-on, but like it was painted with the car.
Old 03-26-2023, 07:39 AM
foxgapLeMans foxgapLeMans is offline
I've always wanted to add a tach to the hood of my 71 LeMans, but cringe every time I look at my perfect original hood. A guy up the street did it to his 72 and it looks great. I guess a good look under his hood to see what he cut into is my next project. Anyone else do theirs? GREAT THREAD!!
The Following User Says Thank You to foxgapLeMans For This Useful Post:
