1965 GTO front drum backing plates very nice 31000 mile car
brake shoe rub pads show it no wear marks ,, straight ... media blasted .. lite primer.. 150 65 non ac heater control ... real nice from the same car 150 1 cable 25.5" loop to loop 35 works smooth same car 65 2 upper radiator brackets from a lemans and rubbers 35 66 67 rear speaker switch very nice no pitting cut green wires to the radio 75 66 67 drivers door handle outside very nice NO pitting or sander marks 50 1 pit on bottom of thumb button 67 HURST 4 speed handle only real nice original 125 67 convertible 4 speed tranny crossmember sits on the L brackets I think 67 only 175 65 Tempest custom dash plaque ... pretty darn decent its a 7/10 35 65 64/66 ? automatic console shifter top plate and w lens n bulb carrier both good retaining clips n nice chrome 45 needs paint 65 blinker arm mint no pits or scratches off 31k column 64-66? .. 100 65 front stainless windshield 225 real nice 65 rear window stainless 225 real nice 67 rear drivers side cove stainless trim fair good tab but has a ding 20 4 power window switches 4 bank drivers and 3 singles very nice 250 all 64 power steering pump and brackets really nice tank but busted pulley this is the later 64 style .. always covered .. 175 67 drum brake spindles and misc 75 67 power steering pump and brackets and pulley non ac really nice straight reservoir NO pry marks or dents original paint ,,, may have upper alt brackets nice pressure hose for a survivor car .... always covered .. clean inside also 250 67 non ac 9778886 water pump pulley 40 67 HD cooling 5 blade stationary cooling fan looks like a flex but its solid with spacer and correct bolts .... came off a 67 400 with A.I.R. and no fan shroud ... it was a weird 67 manual discs 3 speed manual power antenna fm radio headrest car ....30 years ago 250 never seen another 66-70 dated power steering steering box's 35-250 67 floor shift column a but ruff 75 straight collar...probably needs a blinker switch 67 power bucket seat track real clean working original 650 67 th400 driveshaft real decent 125 67 convert door top stainless trim really nice originals 150 pair 3-67 wire hubcaps 1 nice 2 decent 35 all 3 1965 std rear view mirror and bracket NOT day nite real nice 150 1965 front fender in front of headlight.. splash pans/aprons the little ones perfect originals 100ea or 175 pair 65 muncie shifter mount plate original 40 65 lower door corners 10" square inner outer whole corners from a SUPER dry drivers door .. media blasted bare ..NO RUST PITTING or issues sweet for that corner repair with original excellent metal ... 75 pair 67 8 track player untested from big car NO fascia s or surround or knobs 75 67 dual gate ... this was the 67 replacement shifter ... bent HURST handle like the OLDS had but all 67 gto underneath brackets and top plate are all GTO very very nice period correct .... these were sold in the speed shop and magazine to replace the 2 speed shifter .... 450 ... post up here first please then hit me up at 2o6 465 9165 till 1030 pm Pacific or Scott68GTO@comcast.net Scott T Last edited by Scott Thelander; 02-25-2019 at 11:10 PM. |
You got mail Scott.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
65 upper radiator mount brackets
and 65 slash aprons in front of headlights have sold on line ... Scott |
Hi Scott,
May be interested in 65 standard (painted) inside rear view mirror w/brk. I’ll call you later today. Thanks, Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
power steering pump has sold I have others also
drive shaft has sold |
turn signal arm has sold
power seat sold for 67 gs skylark wagon build the mirror is sweet ! exc around the edge ... no fogging ... the rear shows patina ... thin paint and I wrapped it in a shop towel to not get scratched... has lite rust 2 weird lines in the casting by the mounting screws .. definitely looks to be under the chrome .... front window trim traded locally rear window trim double checked and VERY nice a couple nice front singles available I will start a new ad after next sale or update I have a few more items to add ... Scott |
whatever came of the drum brake backing plates ?
Bump
