Old 05-01-2023, 08:54 PM
67428HO 67428HO is offline
Default 67 Firebird clock guts
Hello ,does anyone make a replacement movement for a 67 Firebird console mounted clock? I have found some that are for the Camaro clock with ralley gauges. Are they the same? Thanks!!!
67428HO
Old 05-02-2023, 11:30 AM
Cammer-6 Cammer-6 is offline
Firebird used a different color backround
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-03-2023, 09:19 PM
gtobird's Avatar
gtobird gtobird is offline
Yes, agree. The guts are the same as Camaro. Only the color of the face is different, possibly along with the mounting base. Unless you know the color difference of the face (which is minor), you would think they are identical.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 05-04-2023, 10:05 PM
Can’t answer your question directly but I had a new movement put in my ‘67 Bird’s clock about 35 years ago and it’s still keeping good time, so there are solutions out there. Retained the original dial, hands, etc., just replaced the movement behind the dial, and I think that’s what you’re trying to do.
Good luck.
Old 05-05-2023, 01:08 PM
SMS sells quartz conversion kits. They work great and last forever. N-3805 is the kit you need.
