Old 04-30-2023, 01:34 PM
jonra3 jonra3 is offline
I sure will put some pictures up, should be hear Monday 5/01/23
  #42
Old 04-30-2023, 01:51 PM
I'll post some pistures as soon as they get here. They said 05/01/23.
  #43
Old 04-30-2023, 03:59 PM
Ramairnacho Ramairnacho is offline
Default Tip
Who do I talk to the quoted me 2k. My friend owns a local muffler shop and I could probably get new system for under 1k. . Sometime I hate telling vendor what I'm restoring because I feel they Mark up price. I believe x pipe reduces back pressure and flow but what do.i know. Im.not building concourse I just want it back.to.stock as close as possible.
  #44
Old 04-30-2023, 04:22 PM
Formulabruce's Avatar
Enjoy a better than stock Gardner Exhaust that , well, is Stock aside from Better exhaust tips.. look how much you have into your air cleaner.. your car deserves the Gardner..
Tip: don't collect seconds or thirds of parts you have and concentrate on getting it done!
The research is fun, but can cost money that now isn't buying exhaust... just my humble opinion.
" Long may we DRIVE !"
The Following 2 Users Say Thank You to Formulabruce For This Useful Post:
  #45
Old 05-09-2023, 11:41 AM
unruhjonny's Avatar
Well I figured I'd update this thread, recently an old stock SR set came up for a great deal here on the forum, and they were quickly snapped up;
At the same time another later made (same number) set had been on eBay for about a month, and those too recently sold.
You can see between the two that the way they were manufactured DID indeed change.
The early ones have (as previously shown in this discussion) the part number stamped up on the small collar of the pipe, while the later ones have the part number stamped on the top rear edge.
The early ones are also a mandrel type bend (I don't know what it would be called; the pipe diameter does not reduce), while the later ones have a reduction in the bend.
The following images are of the older stock SR tips:
Name:	NOS 481525 Exhaust Tips 03.jpg
ID:	612299   Click image for larger version
Name:	NOS 481525 Exhaust Tips 04.jpg
ID:	612300   Click image for larger version
Name:	NOS 481525 Exhaust Tips 01.jpg
1970 Formula 400
  #46
Old 05-09-2023, 11:43 AM
unruhjonny's Avatar
Since I can only upload five images per post, I am continuing from my last reply;
The following images are of the later SR tips to see the differences:
Name:	NOS 481525 later SR exhaust tips 03.jpg
ID:	612304   Click image for larger version
Name:	NOS 481525 later SR exhaust tips 05.jpg
ID:	612305   Click image for larger version
Name:	NOS 481525 later SR exhaust tips 07.jpg
1970 Formula 400
  #47
Old 05-09-2023, 04:10 PM
kingbuzzo kingbuzzo is online now
They all look the same to me....you should be a fb curator lol
Old 05-09-2023, 04:25 PM
unruhjonny's Avatar
ok, other than the number stamping, here is a side by side.
Since the forums resizes images, go back and look at the larger images, and you will see it.
I believe that in addition to them being manufactured with the compression bend, that the later ones are lower quality - it's only the later ones that seem to have rust problems.
Name:	NOS 481525 Exhaust Tips comparison.jpg
1970 Formula 400
  #49
Old 05-09-2023, 11:43 PM
oh i believed you before but amazed by your research on the subject...
hopefully you don't put my car under the microscope lol...just jokes 😀
Old 05-10-2023, 12:41 AM
unruhjonny's Avatar
that wouldn’t be my style…
finding these details is kinda fun… to weirdos like me.
1970 Formula 400
  #51
Old 05-10-2023, 12:13 PM
Expert level...
Old 05-14-2023, 11:33 AM
http://forums.maxperformanceinc.com/...1&d=1684077645Hi here are the pictures of the 70 exhaust tip from Gardener Exhaust
Name:	Garner Exahaust Tip 3.jpg
ID:	612629   Click image for larger version
Name:	Garner Exahaust Tip 4.jpg
ID:	612630   Click image for larger version
Name:	Garner Exahaust Tip 5.jpg
ID:	612631   Click image for larger version
Name:	Garner Exhaust Tip.jpg
The Following User Says Thank You to jonra3 For This Useful Post:
  #53
Old 05-14-2023, 12:56 PM
Default The 70 tips
So those the correct tips for 70 formula? If so im.in.
  #54
Old 05-15-2023, 03:07 AM
Transamric's Avatar
Your cat seems to like 'em!
The Following User Says Thank You to Transamric For This Useful Post:
  #55
Old 05-15-2023, 04:56 AM
Trevor78 Trevor78 is offline
Says 74-75 but may be of use somewhere here to compare.
https://www.ebay.com/itm/32564324166...Bk9SR7rx9emDYg
  #56
Old 05-15-2023, 11:40 AM
Kitty gave his OK on them. the chrome plating is really excellent. I can't see any defects. Its a bright, deep, and smooth finish.
I can post some more pictures, thanks to unruhjonny for the instructions on posting pictures.
  #57
Old 05-15-2023, 12:04 PM
unruhjonny's Avatar
those look great!!
1970 Formula 400
  #58
Old 05-18-2023, 04:58 PM
Held for Ransom's Avatar
Yeah polished is good. If I find good set I'll have rechromed maybe but I think they starting to band chrome so next options cut the 45 degree to.22 or repop.and polish. Lazy option is run 45 degree
Ignacio, if you want to cut down a set, you would have to use/find a set of '74s. Re-cutting the angle on a set of '71-3 would make them too short.
On a side note, I wonder how many different versions were NOS? I have the later units stamped (part number)FT. Others stamped NJ(part number)(2 places) and NK(part number).
So long, farewell.
  #59
Old 05-18-2023, 05:08 PM
unruhjonny's Avatar
it looks to me like there are two versions or SR exhaust extensions - or possibly three version in total.
1) OEM - likely unstamped; no reduction in bend
2) 1st SR - number stamped on collar; no reduction in bend; appear to be dead ringers for OEM part
3) 2nd SR - number stamped at top/rear of pipe; reduction through bend
1970 Formula 400
The Following 2 Users Say Thank You to unruhjonny For This Useful Post:
