| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
they listed 479 Million dollars in warranty repairs on the Ford 6.0 diesel , that was for those who were lucky enough to still be in warranty. I bet those engines cost the company i work for in excess of 10 million dollars. A good number of those F-350's we just scrapped after their 6.0s died.
| The Following User Says Thank You to tanksteve For This Useful Post: | ||
The disappointment with the 5.7L Olds diesel was the damage done by the first generation clouded perception of the second generation. The first suffering from severe lifter and cam lobe wear from oil contamination. Owners did not realize the importance of the 3000 mile oil change with the diesels compared to lazier practices with gasoline engines. The EGR system in the diesel pumped a lot of soot back into the crankcase as blow-by. Additionally, the lack of a water separator contributed heavily to those blown head gasket situations as well as injector pump corrosion.
I had a 1981 Bonneville with the second generation 5.7L diesel and had no problems except for a fuel gel-over during the big chill in 1983 until about 70,000 miles. One of my GMI classmates worked on the V-6 diesel development at Oldsmobile and and gave me a few tips on the 5.7L for reliability. The roller lifters in that engine cured the cam wear and a water separator had been added in the fuel filter. My problem was worn out wrist pin bushings leading to piston slap and three bent rods. I found a specialist in OKC that rebuilt them with drilled rods to pressure feed the wrist pin bushing, and he changed the head bolts to the larger diameter ones from the 6.2L diesel. He essentially blueprinted the engine and you could definitely tell the difference with the ease of starting and performance gains. I went another 200,000 miles on the engine before a Texas hailstorm totaled out the car. I never got less than 22 mpg with that car and went as high as 34 mpg on the highway. My biggest complaint was the wimpy Turbo 200N transmission they used. I went through 4 rebuilds due to lock-up torque converter failures. The diesel had too much torque at low rpms before the transmission oil pump pressure was high enough to maintain the lock-up in the converter. Still the best long distance cruiser I ever had though. |
| The Following User Says Thank You to srmmmm For This Useful Post: | ||
At that time I was working as a line mechanic at a buick dealership, and was privy to all the missed maintenance items that got overlooked when diesels were serviced. One main problem was the valve cover breather filters never got replaced, or even washed out at oil changes. Carbon plugged up the inadequate gas engine breathers, and then blowby had no where to go with the plugged breathers. It blew out the rear main seal from too much crankcase pressure. As well as the RTV valve cover seal, no gasket, creating massive oil leaks. letting owners finally run the engine out of oil and causing crank and bearing failures, called reliability problems. As it has been already pointed out, an outstanding car for highway trips. Great comfort as well as great mileage, and at that time diesel fuel was still less than gasoline per gallon. Properly maintained the second gen 5.7 was a fair engine, not great, but adequate in my experience. As the article said from 77-80, they were ticking time bombs. After installing a few 5.7s in pickup trucks GM wisely called upon Detroit Diesel to design the 6.2/6.5 engines for light duty trucks, but they too had some problems from design shortcomings, and penny pinching book keepers. IH/Navistar took on the manufacturing of the 6.5 diesels after GM dumped the design for the Duramax to keep making it for the military for the military Hummers. The IH/Navistar 6.5, is a much improved quality piece over the same GM offerings previously. The Hummer late model government surplus 6.5s are highly sought after as replacement engines for civilian GM light duty trucks. They are a much better built rendition than what GM was making. If the post 1980 diesels were properly maintained, they ran well and got great fuel mileage. In 1985 I drove mine from Erie PA to Phoenix AZ, and best tank was 32 MPG. Hard to argue that mileage in a full size car when the same gas powered car would likely never see 20MPG. My TH 200 never gave up when I had the diesel. When I put the gas engine in, I left the TH 350 bolted to the rocket 350, so the car had a durable transmission when I sold it. Unfortunately the guy that bought it pulled onto the highway in front of another car, and totaled it about a year after he bought it. My injection pump finally went out at over 130,000 miles, and I just bought a used one for it from a friend that owned a wrecking yard. At the time a reman was in the neighborhood of $550, lots of money in the late 80s. Just like the corvair, and the Fiero, GM finally got the cars/engines figured out and working, just before they went out of production due to the bad rap from the earliest models. In the corvairs case, Ralph Nader hastened their demise. Funny too that the IRS 61-63 Tempest used the basically same swing arm rear suspension as the corvair did, as did the VW bugs, but no mention of either of those cars having the same ill handling type of suspension quirks. There were probably other cars that used swing arm rear IRS that I'm forgetting about during that time. GM was famous for doing field testing of new ideas, and making the customers the Guinea pigs. Denying that their designs/ideas were just fine, even though customer complaints proved otherwise. When they dropped Pontiac, I never bought another new car from GM, and never will either.
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Suffice it to say, I made a lot of money selling Motorcraft parts to that fleet while they were my customer between 2010 and 2018. I think the 6.0 diesel repairs actually cost Ford more than $1,000,000,000.00 |
If that Billion dollars is a accurate, that's some SERIOUS money, even for a giant like Ford. Hell, that's 4 NFL quarterback contracts! That should put it into perspective and qualify that engine for the list. I am happy to say I have never worked on one of those engines.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
The Ford Dealership told me that there would be no Ford V8s soon. I mentioned the risk with the 1.0 Liter ECOboost timing BELT soaking in hot oil being a failure timebomb. Ford Engine designers getting away with fundamental crap like organic belts in hot oil seems to be an intentional demise. |
Well i should have qualified Ford Gasoline V8s in Ford Production vehicles. |
https://www.fordracingbyspeedshopdir...EaAqgXEALw_wcB
(1) A Ford Pushrod NA V8 Engine (2) The Ford Dealership told me that there would be no Ford V8s soon. Maybe as far as Ford boosted V8 Diesels go. 3) The Ford 1.0L EcoBoost Fox engine received important updates in 2017. Although thermodynamically similar to its predecessor, it was entirely reconfigured to integrate a new cylinder deactivation system for improved efficiency. A dual-mass flywheel and a vibration-damping clutch disc were also added to quell engine oscillations when running on two cylinders. Offered in two different variations, with different power ratings, the Ford 1.0L EcoBoost Fox engine was awarded the International Engine of Year twice. It powers the following vehicles. Ford Fiesta Ford Focus (European market) Ford EcoSport Ford 1.0L EcoBoost Fox engine was awarded the International Engine of Year TWICE. Obviously the International JUDGES have a different opinion. Tom V. Do the job, and then we can talk again.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
Just Saying the Pushrod Gas engine is ANOTHER example that the conventional gas & diesel engine will be around for quite some time. Tom V. 2.7 million ECOBOOST engine vehicles, (all I wanted was a single dollar for each vehicle, LOL!).
My biggest takeaway from the ecoboost 3.5L gas engine is how tough and reliable they have been in heavy duty use. A fleet of 18 passenger vans with that engine I worked on from 2015 to 2022 didn't have a single major mechanical failure. No turbo issues, no valvetrain, lower end, or even transmission problems. Two of them had over 300K miles on them. Oil leaks, minor coolant leaks, coils and O2 sensors sure. But nothing major. Very impressed. That engine will NEVER make the 10 worst list. It's a V-6 anyway.
When I retired in 2016 Ford Research gave me a "one of a kind" hand made/machined lamp. The words on the plaque say:
Ford Logo Presented to ECOBOOST Logo August T Vaught IN RECOGNITION OF YOUR CONTRIBUTIONS TO FORD POWERTRAIN AND BOOSTING TECHNOLOGY HAPPY RETIREMENT POWERTRAIN RESEARCH & ADVANCED ENGINEERING TEAM That being said the 3.5L ECOBOOST race car that won at Le Mans could run at Le Mans as speeds exceeding 250 mph 3 times each lap (7 miles = ONE LAP) for 24 hours on race day. The 3.5L engine Mike, as you posted, was a very durable boosted engine Mike. Tom V.
I may not know a whole lot about them, but that article is the very first time I have read it being suggested that the flathead ford engine was unreliable.
Older stuff required more maintenance period - maybe the authors personal bias placed it on the list? I also think the the cited three year run of the Chevy 267 (79-80-81) is wrong; It’s possible that the Malibu sedan I had was an ‘81, but I thought it was an ‘82 - it had that gutless small block. It may have been gutless, but it was reliable. The same article suggested that the Pontiac 265 was made for longer than the Chev 267; Is that correct?? I thought I read that the last Pontiav V8 was a 301 - and that it was built in (?)1981…??
The last Pontiac v8 was the short deck 265, I had one in an '81 Grand Prix
"You can observe a lot just by watching" Yogi Berra |
I worked in a buick dealership in 1982-1985, if you ordered a V8 in a Buick there were only 2 choices in 1981, a 307 olds, or a 301 Pontiac, Buick had already discontinued their 350 V8s in 1980. |
As mentioned, take anything printed in an MSN article with a healthy grain of salt.
| The Following User Says Thank You to Stuart For This Useful Post: | ||
Need a follow-up article on 4-CYLs and 6-CYLs. Or auto engines in general, that which only 2 or 3 of the V8s (caddy 4100 & 4-6-8 or olds diesel) would relist.
Me thinks the article is dissing on (gasoline) V8s as narrative. Plenty of epic 4 cyl fails and fewer 6-cyl. V8s the least fail variety. |
4 cylinder engine can live for "X" number of miles 6 cylinder engine can live for "2X" number of miles 8 cylinder engine can live for "3X" number of miles. Lots of 7.3 liter diesels with 300K plus miles on them out there in service. Tom V.
Monza/Vega alum 4 cylinder. A favorite of exterminators everywhere.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400 pontiac 72 4-4-2 Mondello's VO Twister II 1964 F-85 Home of the 700hp small-block Olds **Still wanting a 64 Bonneville or Catalina** |
| The Following User Says Thank You to Mr Anonymous For This Useful Post: | ||
