Old 06-16-2023, 05:39 PM
67drake's Avatar
67drake 67drake is offline
Default Small Digital tachometer
I’m looking for a tachometer for my LeMans. I don’t want a big honking round tach on my steering column like on my GTO, just a little digital tach I can mount somewhere fir when I want to check RPM. It doesn’t have to look stock, stealth, or pretty, just functional.
Now surprisingly a search at Summit shows almost nothing, just your basic old school large round tachs, or modern mount in the dash ones.
I was thinking something along the lines of this, but just a tach, and better quality. Anyone here have any ideas?
https://www.ebay.com/itm/29465359672...3ABFBM0Ivy4Zhi
‘55 Catalina
Old 06-16-2023, 11:22 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I like this little guy. I almost bought one for my Firebird before I switched to Fuel Injection. I think its essentially the size of the shift light that would go onto a Monster Tach.
https://www.glowshiftdirect.com/silv...h-shift-light/
Autometer makes a similar one if you want to pay more and maybe get better quality. Summit used to but they discontinued it.
Getting all my gauges on one little box was actually a motivating factor in going to injection for me. I think there would be a market for just a Terminator style Led screen that you could plumb electric sensors into. I know Holley has the big digital dash, which is cool, but is a hefty priced item.
Old 06-17-2023, 07:30 AM
Radman's Avatar
Radman Radman is offline
You did not mention the year. This is a 63 LeMans cluster that I put a tach in the blank spot where the clock would go. You may be able to do something similar.
Name:	guages everything in front.jpg
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 06-17-2023, 02:24 PM
Bosch makes a ~2" Tach that is accurate. I used the guts to drive a Stock 68 Tach. You could buy from Advanced auto Zone or Harbor freight and use as-is.
Old 06-18-2023, 06:35 PM
SD455DJ SD455DJ is offline
I bought the small AutoGage (AutoMeter cheap line) 8k tach, 2-3/4" diameter. Works really well from what I can tell and seems pretty accurate. I also bought the trio gauge set that is all electric and small too.
Dennis
ID:	614411   Click image for larger version
Old 06-18-2023, 09:07 PM
67drake's Avatar
Thanks for the opinions guys. I was looking for a digital, like Rocktimus Prime posted though.
‘55 Catalina
Old 06-18-2023, 11:37 PM
Nobuddy Nobuddy is offline
Not the prettiest solution but the inductive Tiny Tach will work.
https://tinytach.com/tinytach
Old 06-19-2023, 05:36 PM
VCho455's Avatar
VCho455 VCho455 is offline
Autometer shift light with tach.
https://www.summitracing.com/parts/atm-5348
Or take a look motorcycle tachometers.
https://www.revzilla.com/dirt-bike/t...sku_id=1593941
Old 06-19-2023, 05:49 PM
67drake's Avatar
Thanks guys. I ordered one like Rocktimus posted , but in black.
‘55 Catalina
Old 10-02-2023, 07:35 PM
67drake's Avatar
Another update. I mounted the Glowshift digital tach in my LeMans and love it.
So I ordered one for my GTO to replace the non functional mini tach that’s in there. I got it installed and it was reading about double the actual RPM. I talked to Glowshift tech and they recommended an electronic “filter” be wired in. Not that expensive, about $9, but of course had to wait for it to arrive. I installed it and absolutely no change. It still reads double the RPM. Apparently this tach doesn’t like breaker point ignition, which my GTO has. Now shipping back for a refund. Works great on my LeMans with electronic ignition.
‘55 Catalina
Old 10-03-2023, 08:12 AM
Radman's Avatar
My first thought was the tach is setup for a 4 cylinder. Then I wonder if you have a dual point distributor in the GTO.
Old 10-03-2023, 11:15 AM
67drake's Avatar
I tried the switch on 4,6, and 8 cylinder settings. No change. No dual point, it’s the original distributor.
It’s always possible the distributor is defective, but if their own tech guy says “it looks like it just doesn’t work on your car”, then I’m done with it.
‘55 Catalina
Old 10-04-2023, 03:22 PM
glenn911's Avatar
glenn911 glenn911 is offline
I put one of those tinytac on my tractor it lasted a few months. I contacted the seller, he sent me another one, it dies within a year. There is a battery in there you can't replace I believe.
Old 06-21-2025, 03:30 PM
joes455 joes455 is offline
I'm having the same issue,installed tach without filter and with and still reads 3300 at idle inwhich is only 1200 on my original tach.Im using a mds red coil hooked up to negative side.Anyone got any ideas why?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 06-21-2025, 03:33 PM
Oh forgot to add ,my hei control module is also msd circuit board design.The original in dash tach works perfect
Old 06-21-2025, 05:42 PM
Msd module is a 8364 old style
Old 06-21-2025, 06:13 PM
67drake's Avatar
“I'm having the same issue,installed tach without filter and with and still reads 3300 at idle inwhich is only 1200 on my original tach.Im using a mds red coil hooked up to negative side.Anyone got any ideas why?”
I don’t know, but here’s an update to my update!
The Pertronix in my LeMans was giving me issues, so I went back to breaker points on the LeMans also. Guess what-the tach now reads double just like it was on my GTO!
‘55 Catalina
Old 06-21-2025, 07:40 PM
Radman's Avatar
Did you use the gray wire from the msd to drive the tach?
Old 06-21-2025, 10:15 PM
What gray wire?
Old 06-22-2025, 08:17 AM
Radman's Avatar
Originally Posted by joes455 View Post
What gray wire?
I googled the msd manual for the unit you said you have. There should be a gray wire at the bottom of the distributor to feed the tach. The 6N and 6Al have the same gray wire at the control box.
