65 GTO hardtop, 3.54 gears, 28" tire, ultra wide ratio muncie. Old Faithful 1.0 cam and 1.5 rockers, unported 87 cc edelbrock heads with old-style chambers. 850 double pumper, doug's headers. Street car.
Engine is 505 CID IA2. I own an unported RPM and unported Torker 2 intake. Would it be worthwhile to send the heads and either intake out to get port work done? And if so, is this combo too mild to benefit from a Northwind? Should I go all the way to 340 cfm, 325 cfm, how far out should I go if I have the heads ported? |
It all depends on what your intentions are with a Car. What hp range your looking to be in.
Seems like with 505 cid, it would want a better flowing intake and heads. But then you would also need a much bigger cam too (the OF also seems small for a 505 no matter what), otherwise I wonder if just the intake and porting would matter very much??
Stan
sorry, forgot that part - it's very close to 10:1. I run 92 ethanol free but may switch back to 93 e10 and use an additive to prevent corrosion. 2000 feet elevation in Spokane.
Let’s assume the heads flow 275 cfm@28” ( about average for out of the box ) at .550” lift.
That’s enough to make a super easy 525 Hp through a gasket matched T2 or the Performer rpm with your CID while having excellent drivability with 3.5 series rear gears. Now let’s say your shooting for 600 Hp. Now the heads will need to be ported some so that you have between 290 and 300 cfm available at the lift your cam is providing. At this point also the Performer rpm should get left behind and the T2 ported some besides the gasket match and a 1” blended carb spacer used. So now the question is do you have the hood clearance for that while running a decent air cleaner?
pretty sure I have clearance for a T2 and a 1 inch spacer, the RPM is on the car now. I didn't notice much difference between the two intakes, but we know how butt dyno's are ...
The road paver recommendation is intriguing because then I start to wonder about whether a beehive spring and light retainer might let me buzz it to 6000 RPM or so safely, I have the rev limiter set at 5500 now and it seems to fall off right about then anyway. |
Related question: I have never heard of an ultrawide ratio Muncie trans. Does it have a different gear set than a 2.56:1 ratio?
I got mine before the N cases came out so it's the older supercase. |
Since you might change cams and have to check and adjust your geometry just due to that I want to ask you to take full advantage of those Aluminum heads and cut them to get over 10 to 1.
Steve C. Has a 505 combo, I am sure he has some experience to help.
My knowledge gained here, and from others...a dual plane intake loses its advantage over a single plane, the larger the cubes are...a 505 needs the T2. I wonder what others think the choke point is on your current combo? I really don't think it is the cam...... The cam core availability situation would push me away from a cam change, at least until things improve. If... Don't get too crazy the the HP.. Might be too much, when you're running your mudgrips!!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
| The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
Yeah I mean the car is already unreasonably fast for any sensible person ... but I guess dorking around with your hot rod is half the fun so ... it's always fun to think about changes I could make.
Want to keep it nice and drivable and reliable so that's the main thing, but I think another step up would still be pretty livable ... maybe add a gear vendors at some point ... |
When I first put my 505 together I dyno tested with a Performer RPM intake and a Victor intake. Both manifolds were port matched to the heads in use and both tested with the same custom HP950 Holley carb. The only difference was the RPM intake had a 1/2" carb spacer and the Victor had no spacer because of the hood clearance issue. The RPM intake was a disappointment with only about 615 HP at 5800 rpm. The Victor depending on the pull made 638-642 hp at 6000/6100 rpm. This was with a custom Crower solid roller cam with 260 degrees intake duration. When I went from the previous 4.210" stroke 462 CID engine to the 4.250" stroke 505 CID combo I added 6 degrees intake duration. The 462 engine used a 254 degree solid roller cam. On both engines the RPM intake made peak power at 5800 rpm and the Victor made peak power at around 6000 rpm.
After that dyno session we decided to change the cam. I got rid of the Crower cam and put in a UltraDyne MSP solid roller cam from Bullet Racing Cams rated with 255 degrees intake duration and went from .4200" lobe lift to .4300" lobe lift. Both cams had a 110 LSA. For the most part no other changes were made except we cut the Victor intake carb flange down 0.650" to help with the hood issues and the engine was dyno tested again. This time knowing the combo thrived on the single-plane intake we never bothered to test with the RPM intake. With the new cam it made about 660 hp at the same 6000 rpm. The engine uses Edelbrock heads with about 320 cfm and it only has 10:1 compression. . .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 06-22-2023 at 05:13 PM. |
Until you understand how it all works you’ll be swapping cams…intakes from now until the cows come home. And spent twice the money. Another idea going from a port matched intake to a fully port and pick up 30 more hp. So now as example that 330 intake now actually flows 330 cfm.
If it were me I'd want more cam in a 505 as the old faithful is on the small side for that engine.
With that said I wouldn't want to bother with head and intake work if a cam swap isnt in the cards. I would however want a single plane intake on an engine that large even as it sits now, preferably with a spacer. Bottom end torque would not be a concern with an engine that size. Other than that, without a cam change I'd be inclined to leave it alone. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
I mentioned horsepower in the previous post. Now looking at the torque curve for the two intakes on my 505. Again on the first dyno session.
I discounted the pulls under 3800 rpm, some numbers looked a bit erratic. At that 3800 rpm the RPM intake was up 27 ft. lbs. torque over the Victor intake. At 4200 rpm they were dead even with the exact same 625 ft.lbs. torque. The RPM intake made it's peak torque at 4400 rpm and here is where the Victor intake started to make more torque over the RPM intake. The Victor intake made peak torque at 4400/4600 rpm depending on the pulls with 635-639 ft.lbs. torque. At 5000 rpm the Victor was up by 19.1 ft.lbs. torque, at 5200 rpm up by 23 ft.lbs torque. At 5800 rpm the RPM was down 18.6 ft.lbs. torque, and this was where it made peak power with 615.5 HP. The Victor intake continued to make peak power up thru 6000 and higher rpm, depending on the pull. On the previous post I stated a best of 642 hp but looking again I found a dyno sheet with 647 hp at 6200 rpm. ( side topic... I mentioned a change to the use of a UltraDyne MSP solid roller cam after the Crower cam. By no means is this any type of recommendation here ! That was UltraDynes most aggressive series of solid roller cams and I had some roller lifter issues using it. In an effort to run a less aggressive cam and to lessen the spring pressure but with the same 255 degrees intake duration I worked with Tim at Bullet Racing. I no longer have the MSP roller ) .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
From the internet.... While longer runners tend to work well at the lower rpm range, shorter runners favor the upper range of the rpm band. Plenum size also has a dramatic effect on power production. Smaller plenums, like those in a dual-plane manifold, do well in the lower rpm range while larger plenums, like the single plane manifolds, tend to boost the top end of the rpm range.
As cast average runner length: Performer RPM intake - 6.28 Torker II intake- 6.06 Victor intake- 8.82 As cast average plenum volume (cc): Performer RPM intake- 1400 Torker II intake- 1195 Victor intake- 946 ( My 4150 Victor intake has no plenum work, only a port match and light runner blending. It has supported a 4.125" stroke/450 CID combo at 7000 rpm with 684 hp. With a Brad Urban Carb Shop Stage III Holley 750 carb ) . . .
| The Following User Says Thank You to Gach For This Useful Post: | ||
