Old 06-25-2023, 07:31 PM
cnc's Avatar
cnc cnc is offline
Default Windshield trim clips
Looking for windshield trim clips …who has the best clips available that are the same as the originals…..thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 06-25-2023, 11:17 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Shoot an email over to these guys at Belden Speed & Engineering via this site: https://www.rustreplace.com/
Possibly the nicest guys I’ve ever dealt with and they know every intricate detail.
The Following User Says Thank You to Entropy11 For This Useful Post:
Old 06-26-2023, 10:32 AM
roy381 roy381 is offline
Wow that is a very informative site.
Thanks for sharing!
Old 06-26-2023, 11:12 AM
pfilean's Avatar
pfilean pfilean is offline
Or maybe https://www.clipsandfasteners.com/
Also might try a Restoration Specialties in Windber, PA
Old 06-26-2023, 01:39 PM
Entropy11's Avatar
Thanks for sharing!
No problem. I remember doing a bunch of research about clips and such thinking j knew exactly what I wanted to be “correct”. One email to them and they gave me the most detailed and personalized response including old pics and history about factory installs… it was crazy.
They even wanted me to get back to them knowing how the install went. Great guys. That website has an unbelievable amount of links to specific details.
Old 06-26-2023, 07:07 PM
cnc's Avatar
cnc cnc is offline
Contacted these folks they do not stock OEM style f body clips…
Old 06-26-2023, 08:09 PM
Trevor78 Trevor78 is offline
No need to reinvent the wheel, many places sell them. Stick to metal for OE trim, may need the later plastic replacements for trouble areas on repro trim. Any restoration parts shop should be able to supply, you are using an Ames forum...
Old 06-30-2023, 02:07 PM
Cammer-6 Cammer-6 is offline
try Au-ve-co they are an OEM supplier
keep in mind there are many clips to chose from so best to have one you know is correct to match up.
https://www.auveco.com/moulding-clip...iners-2?page=3
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-03-2023, 10:24 PM
kpbrown31 kpbrown31 is offline
I've always had good luck with Restoration Specialties when trying to find information or source an unusual clip. Otherwise I've ordered clips from OPGI.com. Our cars are different, but worth a try.
Old 07-04-2023, 06:30 AM
cnc's Avatar
cnc cnc is offline
Got some locally thanks
