I have SSBC rear disc brakes on my 65 GTO.
The E brake part of it doesn’t work worth a damn!! I learned they are ford thunderbird based, lol Can anyone recommend a caliper that would be a direct replacement with an Effective E brake ? Trying to avoid another “Kit”. If that is possible. It’s a 4 sp trans. Thank you. |
How thick is the rotor?
Don’t know , have to measure it.
Kit was installed 5 or 6 yers ago and I don’t recall specifics I’ll let you know. 👍 |
Takes this pad if that helps.
Pad does not help - Ford used that pad on several calipers with different thickness rotors, so different caliper frames.
You will need to measure here. |
A cursory search shows nothing of the usual suspects running a 1/2" thick rotor.
Best bet is to have B&W Brake in KCMO rebuild them for you. Once this is done, every time before you shut off the car, engage the parking brake. This will keep it in form. |
![]() Quote:
Means ? |
They need to be used regularly or they freeze up.
The 69 Lemans I recently acquired has SSBC rear brakes and I called the company directly- Tim was great at answering questions- maybe call them for the specs on your rotors.
(716) 775-6700
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
