Old 11-15-2025, 12:41 AM
Shiny Shiny is offline
Always good to hear a happy ending. Nicely done!
Old 11-15-2025, 01:29 AM
BB70's Avatar
BB70 BB70 is offline
Thanks, I like happy endings 😃
Old 11-15-2025, 06:11 PM
Quick wash and vac..
Old 11-15-2025, 06:12 PM
Quick wash and vac.. Paint looks a lot better in the pics than it really is.
The Following 6 Users Say Thank You to 71GP76TA For This Useful Post:
Old 11-16-2025, 07:10 PM
carcrazy carcrazy is offline
I sat down inside my 67 GTO and looked at the wiring mess with the intentions of getting it straightened out. Dragged out the wiring diagram, looked back at the mess. Got up and went into the house to watch football.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
Old 11-17-2025, 12:47 AM
Verdoro 68's Avatar
Resealed the window in the Ventura yesterday. The urethane I used to set the rear window a while back didn't hold and I didn't have time to fix it before we left. It squeaked the whole time on our road trip! I write off the failure to user error. We were in a rush and I couldn't find any primer. I also didn't have the proper caulking gun so it was really hard to apply.
This time we used the old school 5/16" roll of butyl Window Weld. It put the window at the perfect height and the trim sits nicely. A storm came though today and it looks like our install was a success. We also sealed up the tail light housings with some 3m strip-calk. So far so good!
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 11-20-2025, 12:39 AM
PAUL K's Avatar
PAUL K PAUL K is offline
This bought went the full twelve rounds... I've fought tougher fights, but I don't remember when.
ID:	661041   Click image for larger version
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 11-20-2025, 11:24 AM
JLBIII JLBIII is offline
Pulled the engine out and took it to Jim Pickett for some upgrades and to find out why there was a serious drop in oil pressure.
The Following 3 Users Say Thank You to JLBIII For This Useful Post:
Old 11-23-2025, 02:43 PM
Went to a Car-B-Que at a friends house yesterday.
The Following 9 Users Say Thank You to 71GP76TA For This Useful Post:
Old 11-23-2025, 06:25 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Attachment 661174
I see you drove your SD. Looks like a lot of nice cars showed up.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 11-24-2025, 08:57 PM
Yep.. It was the only one there..
The Following 3 Users Say Thank You to 71GP76TA For This Useful Post:
Old 01-08-2026, 07:07 PM
burd burd is offline
Original kilometers?
I drove my ta in Canada, so my orig miles are all messed up.
Old 11-24-2025, 12:33 PM
[QUOTE=71GP76TA;6592667]Went to a Car-B-Que at a friends house yesterday.
dang...i would never leave lol
Old 11-24-2025, 01:14 PM
jhein's Avatar
jhein jhein is offline
Attachment 661174
That's awesome
Old 11-23-2025, 02:57 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Did 100 mile country cruise this morning down over the Ohio river from Kentucky to Indiana and back home . Enjoyed some coffee and a podcast along the way .
When I wore a younger man's clothes
The Following 4 Users Say Thank You to locomotivebreath For This Useful Post:
Old 11-23-2025, 10:34 PM
Drag Star Le Mans's Avatar
Quick spin in the 73 Formula and parked it outside under cover.
ID:	661185   Click image for larger version
DragStarLeMans
The Following 8 Users Say Thank You to Drag Star Le Mans For This Useful Post:
Old 11-24-2025, 08:26 AM
I swapped out the rear lower control arms on the 1971 Catalina Freeway Enforcer so I could remount the 7/8" rear bar the PO had removed and swapped out the arms with ones that didn't have mounting holes for the mounting brackets for the rear Bar. The new arms were a NOS Kit that was intended for the recall on the 91-96 Caprice's with the 9C1 Police package or Taxi cabs. They were breaking the rear control arms at the 4 smaller holes used to mount the rear sway bar mounting brackets inside the C section of the arms. The upgraded arms use 2 thru bolts to mount the Bar thru the control arms upper surface. They use spacer around the bolts, and small plates that overlap the lower control arms. Comparing the 2 control arms, the only functional difference I could find was the distance between the front and rear bushings was 1mm longer hole center to hole center on the new arms. This was probably the easiest control arm swap I have ever done but as stated the PO had swapped them out about 25-30 years ago, and the car has less than 35K original miles on it, even if it is a rust belt car.
And while I was there I took the time to clean up the large 12" finned rear drums, even though you can not see them with the wheels installed.
Name:	arm comparision side.jpg
ID:	661192   Click image for larger version
Name:	arm comparision bottom.jpg
ID:	661193   Click image for larger version
Name:	rear bar installed.jpg
ID:	661194   Click image for larger version
Name:	rear bar installed hardware.jpg
ID:	661195   Click image for larger version
Name:	71 enforcer rear brake drums.jpg
The Following 5 Users Say Thank You to camerjeff For This Useful Post:
Old 11-24-2025, 01:27 PM
Look's like a good time there.
Old 01-03-2026, 10:39 PM
Redpiston Redpiston is offline
Spent 3 days getting ready to bring the 66 2+2 back to KC from Richland Washington. Emptied out the third car slot, painted walls and ceiling, built a couple of 4ft x10ft shelves to put all my car parts on, and packed away all the tailgating supplies since we are done for the year.
The Following User Says Thank You to Redpiston For This Useful Post:
Old 02-09-2026, 09:59 AM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
I moved the snowblower out of the way and took the Pontiac out for a cruise both Saturday and Sunday, then drove it to work this morning as well.
February temps in the 50s in South Dakota is nice enough for hot roddin'!
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 6 Users Say Thank You to 73_Lemans_350 For This Useful Post:
