Old 08-15-2023, 01:56 PM
T/A addict T/A addict is offline
Default Thoughts on this 455 build?
- 1971 GTO 455 YC
- 9.5:1 compression
- .030 over, forged pistons, reconditioned rods, new bearings, new expansion plugs, ARP hardware
- 1971 400 #96 Heads - Comp 995 springs, stainless valves, viton oil seals, hardened valve locks, screw in studs and guide plates
- Spotts Performance Ram Air IV 041 Cam and Lifters
- Spotts Performance Stainless 1.6 7/16 roller rockers w/ poly locks
- Spotts Performance 7/16 screw in rocker arm studs
Old 08-15-2023, 02:03 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Strong street motor. Heads ported? Intake?
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 08-15-2023, 02:08 PM
Mr Twister's Avatar
That is a very popular combo from the pre aluminum head days. Get better rods and a modern cam profile. There is no reason to use stock rods anymore. You can get better ones for what it costs to redo old rods with machining and bolts. You are going to get lots of opinions... good luck!
The Following 2 Users Say Thank You to Mr Twister For This Useful Post:
Old 08-15-2023, 02:40 PM
I don’t like the CC 995 springs due to the flat wire damper in them.
I prefer Crower 68407 springs which are a duel coil spring like the factory ones.
Crower 87408 retainers should be used with them.
By the time you get done rebuilding the factory rods you will really not have gained much strength and spent just about the same amount of bucks as investing in new stronger rods.
Also since due to the new forged pistons you will need to rebalance the motor, then the far lighter aftermarket rods will allow the motor to rev up a good amount faster.
You should take advantage of that and the fact that the bearing and block loads will be less.
Old 08-15-2023, 07:50 PM
Half-Inch Stud Half-Inch Stud is online now
My buddy Goodman suggests the rods be replaced with new forgings.
Old 09-05-2023, 12:51 AM
64speed's Avatar
64speed 64speed is offline
I am using those springs with the Crower 60919 cam and it seems to be pretty good
Old 09-05-2023, 06:02 AM
Geez, a opinion from you and not a question!
Old 09-05-2023, 11:09 AM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Great street combination, should run real well with a good efficient 2800-3000 stall converter and 3.23-3.42 gears
1978 Trans Am
Pump Gas 461 Stroker
Old 09-05-2023, 11:45 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Originally Posted by T/A addict View Post
- 1971 GTO 455 YC
- 9.5:1 compression
Aside from the 1.6 roller rockers, I have this exact combo in my 67 GTO currently. Works well with Manual trans.
My suggestion would be a Performer RPM manifold to top it off if hood clearance is not an issue.
Enjoy!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 09-05-2023, 01:18 PM
64speed's Avatar
I’ve been on this forum since 2003. Lots of opinions.
The Following User Says Thank You to 64speed For This Useful Post:
Old 09-05-2023, 02:47 PM
Tim Corcoran's Avatar
Try these rods, stronger than stock and plenty strong for your build.
https://butlerperformance.com/i-3164...tegory:1459645
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 01-17-2024, 07:50 PM
General Z General Z is offline
- 1971 GTO 455 YC
- 9.5:1 compression
So, did you build it exactly like that? I have a similar setup and am debating what parts to go with.
Old 01-17-2024, 10:45 PM
Gach's Avatar
Gach Gach is offline
Well he’s talking from experience nothing better than that.
The Following User Says Thank You to Gach For This Useful Post:
