Old 09-06-2023, 04:56 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Question Add in dash tach
What’s involved in adding in dash tach ?
Doing the rally conversion and like to also imitate the bulky aftermarket tach.
Thanks.
Dominick
Send it! It’s going home on a trailer.
Old 09-07-2023, 09:23 AM
What bulky aftermarket tach?
Why not the stock in-dash tach to go with your rally gauges?
Old 09-07-2023, 09:35 AM
nh68gto's Avatar
Yes that’s what I’m asking.
* eliminate lol bulky after market tach.
Old 09-07-2023, 11:56 AM
Yeah, I need to swap my inoperative in-dash tach for a clock I purchased after installing a hood tach.. Been putting it off because I don't think it can be done without removing the instrument panel. I've done that a couple of times and it's not something I'm looking forward to doing again..
Of course, mine is a '68... completely different dash if you're dealing with a '69.
Old 09-07-2023, 06:42 PM
SD455DJ SD455DJ is offline
It was pretty easy...just plug & play basically. We were able to install it without removing the radio or heater controls, but it is a tight fit, so plan accordingly. This is an older reproduction in-dash tach that fortunately did work (reads about 5% high throughout the rev range). It used the same connections (2) as the filler plate and connect the wiring as per the instructions. The original owner installed an aftermarket tach in the right-hand pod that the repro tach replaced.
Dennis
ID:	619599   Click image for larger version
Old 09-07-2023, 07:32 PM
Cammer-6 Cammer-6 is offline
5% is easily corrected with a cap
Wheres Padgett when you need him :^(
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-07-2023, 07:39 PM
Shiny Shiny is online now
It was pretty easy...just plug & play basically. We were able to install it without removing the radio or heater controls, but it is a tight fit, so plan accordingly. .........
Dennis
I think your definition of easy may be different than mine - that's impressive! I think I have a bad connection to the dash speaker(s) and have been dreading trying to reach up there. I'm afraid if I lay on the floorboard I will never get back up. Where doesn't it hurt?
Old 09-07-2023, 08:29 PM
Well, with all the work we've been doing to the car, it was pretty easy...comparatively...lol. Also, it doesn't have AC, which opens up the under-dash immensely! Dan and I can relate to the increased length of time it takes to crawl out from underneath the dash these days...not to mention the aches and pains that come with it.
Dennis
Old 09-07-2023, 08:31 PM
Cammer, what's a 'cap'? Never heard of it...but, I'm not really knowledgeable with gauges and other gadgets electrical.
Dennis
Old 09-07-2023, 08:51 PM
Capacitor.
Old 09-08-2023, 01:47 PM
vertigto's Avatar
vertigto vertigto is offline
Make sure it's calibrated first.
Old 09-10-2023, 05:29 PM
Capacitor.
Ahh, OK, I've heard of those things...lol! Thanks for clarifying!
Dennis
Old 09-10-2023, 05:44 PM
Just make sure it's not a Flux Capacitor...you could wind up in 1982.
Old 09-10-2023, 05:46 PM
Don't you have to be standing on a toilet first???
Dennis
Old 09-10-2023, 05:47 PM
Lol
Old 09-10-2023, 06:15 PM
einstein's Avatar
Padgett still had his tach repair side business when we first met. I recall him marking the circuit board with a track of pencil graphite to calibrate a hood tach. He said they all read high from the factory.
