#3501
70 GTO NM in Indiana at $46K BIN with 100K miles. Seems reasonable for this car as it's really nice.
https://www.ebay.com/itm/27608069926...Bk9SR4y2of3eYg ![]() ![]() ![]() ![]()
| The Following User Says Thank You to thews For This Useful Post: | ||
#3502
[QUOTE=thews;6458608]69 Firebird in Canada at $145K BIN. All blacked out with lots of hot rod parts.
Needs more black...
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#3503
[QUOTE=kingbuzzo;6458670]its a murder of crows
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#3504
68 Firebird at $27K NR in NY. The ad is lacking in pics. The only shot of the interior is the restomod gauges. Has a 12 bolt posi. The car sits too high, especially for the 70's rear flares. There's things I would need to change on this car (the hood) to make it more stock, so I wouldn't be the type of buyer that this car would appeal to.
https://www.ebay.com/itm/23524261495...Bk9SR8qjpprgYg ![]() ![]() ![]()
#3505
68 GTO 4-speed posi with the Royal Pontiac paint job at NR $15.5K in Michigan. It'll sell.
https://www.ebay.com/itm/16636399845...Bk9SR8yjpprgYg ![]() ![]() ![]()
#3506
68 GTO convertible 4-speed in Florida at $30K with a reserve. Beautiful car. I've not owned a Pontiac without FDB for a long time. How would a car like this brake compared to FDB? Is the difference slight, or dramatic?
https://www.ebay.com/itm/39491868231...Bk9SR_qDkp3gYg ![]() ![]() ![]()
#3507
[QUOTE=thews;6459102]68 Firebird at $27K NR in NY. The ad is lacking in pics.
Tip toed...i dunno. It has some old school charm
#3508
And I like the white top. |
#3509
I've been looking at '68s too long. At an initial glance it shows well, but I see all sorts of stuff when I look closer.
- wrong bolts for the radiator cover/fasteners under the hood - missing thermostatic vacuum lines on the intake - wrong valve cover vent tube - alternator bracket looks funky, but may be right for non PS car? - black painted headlight bezels - wonky endura gap at the front fender - missing 1/4 trim, missing trunk emblem, fat door gaps, bent front valance, the GTO badge in different locations on the left and right fenders, and the way the side marker light sits in the 1/4 indicate some potentially sketchy bodywork under that paint - painted dash bezel vs. chromed - wrong lug nuts, trim rings and RII color - unpainted RII spare - washer container mounted on the driver's side fender - hacked out dash for aftermarket stereo - spray bombed underhood with trash and fish eyes in the paint - different brand front and back seat covers (look at the depth of the grooves) - wrong brake/clutch/parking brake pedal pads + pedals too high - wrong headlight knob Among other things... I think this was hastily dolled up for a quick sale.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#3510
Yes, lots of things wrong. Some easily correctable, others a bit more labor/money intensive. Not to mention the PUI seat covers and whatever is under the sheet metal of a FL car. |
#3511
Rear arrowhead lenses look to be for a Firebird. GTO/Lemans lenses protrude from the bezel. Some vendors are unaware of the difference
Vent window frame missing the door window runner. As mentioned, looks nice, but...
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
#3512
That’s because the 68 Firebird quarter is quite flat in that area and the 68 GTO - 68-69 LeMans is very rounded.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
| The Following User Says Thank You to north For This Useful Post: | ||
#3513
positioning of gasket makes a difference also
#3514
https://www.hemmings.com/stories/201...lepalooza-xxix https://bringatrailer.com/listing/1968-pontiac-gto-19/
#3515
67 Resto-Rod Firebird in Connecticut at $15K reserve not met. Not the direction I would have taken it, but looks like a lot of work was done. WIW...?
https://www.ebay.com/itm/25624466368...Bk9SR9C05-zgYg ![]() ![]() ![]()
#3517
We've seen this one before, but after really looking at what went into this car, I think it's a lot of work. 69 Firebird convertible in Pensylvania at $57K BIN. Looks like a frame off to me. The engine has aftermarket aluminum heads, so all the number crunchers should stop here, because this isn't a numbers matching car. Those heads allow you to run 1.0 more compression without pinging over factory heads, so they're really better. It is very nice IMO. I can't imagine doing all that work for $57K?
https://www.ebay.com/itm/32583710840...Bk9SR5DErfLgYg |
#3518
Ya don't see these clones come up too often. 1962 Pontiac Catalina Super duty clone at $26.5K BIN in Missouri. Has a 455
https://www.ebay.com/itm/13475554829...Bk9SR5LErfLgYg ![]() ![]()
#3519
67 Firebird with a supercharged Corvette LS2 with AC at $90K BIN OBO in CA. The add looks odd and is lacking in pics, but a lot went into this car. I'd bet it's crazy fast.
https://www.ebay.com/itm/29596574416...Bk9SR5LErfLgYg ![]() ![]()
#3520
68 GTO 4-speed in NJ at $20K reserve not met. Says it's built to Ram Air II specs. I has RA exhaust manifolds, but I can't make out what the head cast number is? .
https://www.ebay.com/itm/22580120726...Bk9SR5rErfLgYg ![]() ![]() ![]() ![]() |
