RAIV on Hemmings
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
The Following User Says Thank You to 71GP76TA For This Useful Post: | ||
Thanks for posting it will be interesting to watch
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Cool car. $120k you think?
Not trying to knock the car but would you think when the did the restoration they would put the correct fender supports in. Just a peeve of mine maybe with early 2nd gens. A RAIV is certainly worth it. Don't get me wrong, I'd love to own it!
The Following 3 Users Say Thank You to necdb3 For This Useful Post: | ||
The wheels are ? " no issues" is what it says.. REALLY?
Shifter issues? Fender wrong... For a real investor, Not a flipper.. its not as correct as it should be. Might go for $165 K . On the auction writers... I dislike the more common auction writers languages about items. Example. " The " correct" transmission sits behind the blue engine" what does " CORRECT "actually mean? Or , " a proper 3 speed turns the drive shaft" < just stooopid > " a quadrajet sits atop the intake" , Really ?? Thats it? " Its said to have the correct gears" , Really, no rear code?? Looked at a 66 Vette Big Block for sale on line. NOWHERE in the ad was the transmission even mentioned, aside from a general " numbers" statement. The Truth WOULD HAVE HURT.. Said like a writer... The giant 427 breathes deep through dual exhaust as it spins the torque converter.... in its BORN WITH Power glide. I barely could see the shifter gear selector in one pic... So much is said to make people assume one thing, but not actually saying it. Rant off..
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 10-30-2023 at 06:23 PM. |
For this car you would think they would get it correct. Thing that screams something bad happened to this car body wise is the incorrect front fenders and the rear spoiler gaps. the shape and gap of the rear QP on the passenger side next to the taillight is closed. not the correct spacing. the other side looks twisted. Body lines and spacing tell a lot about what or how the car was put together. Also the door the QP body lines do not line up at all. I know these cars were not perfect when they left the factory but after seeing a couple hundred of these cars over the last 35 years you can tell the ones that were whooied together. This is not what I would buy for that kind of money.
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
The Following User Says Thank You to skunkwerks For This Useful Post: | ||
In Hemmings back in the early 90s I passed on it then but checked it out , if anybody needs any info send me a message
It’s pretty rare that its original block is still in one piece.
The Following User Says Thank You to Norwood For This Useful Post: | ||
When the 190 watchers gonna start bidding on it?!?
Only at $55k with 3 days left... the 3 bidders and 246 watchers all waiting to the end I guess
I believe this is the 1st 70' RAIV built in Norwood. Regardless of prior restoration faults, it still has it's pedigree.
The Following 2 Users Say Thank You to RAIV70TA For This Useful Post: | ||
The Following User Says Thank You to 65madgoat For This Useful Post: | ||
Top bid was 82,500
Nobody really went after it. Sporting bids |
In all of these years this is the first RAIV auto I've seen. It's not perfect but it looks like a nice car. You don't get many opportunities to buy these
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
Then, I'm guessing mine would be your 2nd one R 70 Judge.
The Following User Says Thank You to RAIV70TA For This Useful Post: | ||
Any idea on how many column shift RAIV's are out there?
With a column shift!! Very cool!
There was a white/blue interior auto on the column Ram4 that sold a couple of different times at the big auctions , several years ago. Was not top notch necessarily , sold for around 100k both times.
In 2006 a friend had just completed a full resto on a 70 Ram4 4spd , white/blue interior. Showed it at 2006 POCI in South Carolina , was offered 125k That was full monte at the time. He turned it down and said next year it will be worth 150k , 10 years it will be double that. He was pretty much right about it. |
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
