I am sure it's a simple adjustment.
When I go to start the car, I have to use my foot on the pedal. Feather a little gas. It won't start unless I do this. Even if I step on the gas once to load it before key switch on starting. Idle is 800 Electric choke. So, I can't just reach in the window and turn the key to start. If that make sense. Even warmed up.
........I'm just learning as I go....... |
Your use of the term “ feathering the gas” sounds to me like you do not have a rich enough condition taking place to start a cold motor .
To start a cold motor you need the near reverse of a warmed up motors 14 to 1 air to fuel ratio that it idles on. The two first things that need to take place to start a cold motor with a Carburetor take place at the same time. You need to pump the gas once or twice to get a good shot of fuel in the manifold from the accelerator pump, and at the same time the choke needs to close off all the way , YES all the way. Next once the motors starts the choke needs to open about the distance of 1/8” or so. The larger your motors cid the more the choke will need to open once it starts up at first.
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
^^^ Sure. When warm tho, if the choke is open and idle adjustment correct, you should be able to start it without messing with the pedal.
George
Choke needs to be adjusted. Make sure the fast idle is within specs. Also check the linkages to make sure they're not binding up. I don't care for electric chokes at all, the open according to time, not temperature. The factory hot air chokes are miles ahead of electric chokes but people are too dumb, stupid, and lazy to get them functioning correctly.
As far as linkages, adjustments and binds there's no difference between an electric choke and one that senses engine manifold temp is there?
Like George, I'm not following the choke connection when the problem is lack of fuel when hot.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 10-30-2023 at 11:02 PM. |
It’s not really clear, but I was assuming by the title of the OPs post that he was referring to cold start up conditions.
I thought the same until reading the very last sentence.
Greg Reid Palmetto, Georgia |
![]() Quote:
He said even if he pumps the gas a full time it doesnt start... so if the acc pump is working then it sounds like the choke needs to be looked at or adjusted for cold starts, could be flooding due to float level or other carb problems? |
When the engine is fully warmed up, have you checked to see that the choke valve is completely open, choke is fully off? If it is, then maybe it's not a choke problem. When you start it warm by applying a little throttle, how long do you have to hold that?
Also, I'm wondering, when you shut the car down fully warm how long before you would have to toy with feathering the pedal to restart? Immediately? 15-20 minutes?
This might help some. (Text on yellow background by Jon Hardgrove)
![]() Quote:
The electric choke can be a good thing for folks working on an older car that has a corroded or damaged air tube that goes in the exhaust crossover. It does take some patience to adjust a hot air choke, but the electric is pretty simple. I live in Oklahoma, the electric choke works very well on my car, since i converted mine!!! ![]()
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
![]() Quote:
None of my cars have corroded or damaged hot air tubes, on one I chose to convert to electric choke based on suggestion from cliff & others, on the other its a factory E-choke that GM started using in 1980 or 81. I drive my cars from early spring to very late fall & all summer long, temps from upper 30's to mid 90's, my electric choke cars dont seem to care what the temps are, at most they might need just a small adjustment to the fast idle speed but the main setting on the choke coil stays the same once adjusted. The hot air choke took a little more adjustment but has worked good in all temps for almost 15 years since getting the carb back from cliff & doing the final adjustments. I agree either type can work good when adjusted right but a hot air choke is not miles ahead of electric and youre not dumb, stupid or lazy to want or use an electric choke. |
Another reason to use one (other than being dumb, stupid or lazy) is my reason.
I have my original '68 intake which is designed for a divorced choke and I'm running a 1974 Q-jet which is designed for an integrated choke. An integrated choke without the provision for the heat tube in the manifold leaves you with a choice of an electric choke or no choke. I ran it with no choke for years but decided I wanted to try one so I went electric.
I have yet to put it in service, but I have an older borg warner electric choke…I guess conversion kit? Has the coil to fit into the carb piece and this gizmo that’s supposed to mount on the intake, some kind of thermostat that alters the amount of current to the coil?
It’s in some box, somewhere, so I cannot provide a part #. I guess a similar thing is still made today? Edit- was kind of like this https://quadrajetparts.com/electroni...evy-p-400.html
costs too much Last edited by rolling money pits; 10-31-2023 at 05:23 PM. |
That one with the temp sensor would address something that I don't like about my electric choke. It heats up based on how long the switch has been on rather than how hot the manifold is. Sometimes when I start my car warm, the choke will kick in anyway. The choke coil cools down before a manifold so as far as it's concerned the engine is cold..
![]() Quote:
One of the drawbacks with electric chokes is that it can get fooled and choke the engine when it does not need to be because as you said the coil cools quicker than the engine. |
The Following User Says Thank You to abefromen For This Useful Post: | ||
