I think you are fine with that. I would run it.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
I talked with the machine shop I use. They said full groove main bearings are not a requirement when using straight shot oiling.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
We use 1/2 and 3/4 groove main bearings in Crower and Moldex billet cranks which have straight shot oiling. I like the extra support for the crankshaft in the cap area.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
Try some Sealed Power main bearings. They normally measure quite a bit small than the Clevite's, thickness wise. They are 3/4 groove too. They may get you the extra clearance you're looking for.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Thanks everyone for the responses. I have one more bearing set on the way and I’ll decide after that what to do. Be watching for bearings on the Parts for sale page .
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
Have the block main line honed to max spec. try diff brands of bearings, they all seem different
Tim Corcoran |
