Gear change effect on convertor?
Racing season is done here in the north east, I am flirting with the idea of going from a 4.10 to a 3.90. Right now I am running a 4.10 with a 30" radial and crossing the line at 6600 at 133 with 7% convertor slip. The car is cutting 1.31 60's. Right now I have an 850 Holley and 340lbs to try and slow it up for 10.0 index. Saturday I ran it all out and ran 9.94. I want to gear it for 142 or so at 6600rpms.
What effect will I gear change have on the convertor and launch? I am worried it will make the convertor less efficient. Will my 60's suffer? Want to take the 340lbs out and put the 1050 holley back on it to see how close I can get to 9.5's. |
The Following User Says Thank You to Mike S For This Useful Post: | ||
The converter will act a little lower. In my experience there won't be much of an et difference.
Wow. Looking to gain nearly 10 MPH at the same Trap RPM. Would you not need the converter to slip at 0 to 1% also with the gear change? With that would your SLR then need to be changed to make up for the loss in converter at launch to keep it crisp? Is the 3 and a half hundred pounds you want to shed equals a tenth per hundred really an exact science or rule of thumb? Wallace calculators?
I want to take the 340lbs out of the car, that should knock .340 of the et on paper. Put the 1050 back on should knock of another .100. My problem is i have to much gear and would cross the line with way to much rpm thus the gear change.
Tuff question!
Maybe break it down into effects on the converter. Less vehicle weigh = less load on the converter and that would bring down the rpm the converter flashes to. Depending on the motors current power band this could be good or bad I would have to guess. Reinstalling the bigger carb equals more torque and Hp. I think you have found what effects this brings to the table if I recall right? The gear change will load the converter harder and in turn using up more or all its stall speed. All and all I don’t see you getting all of the mph increase your looking for, especially since no added rotating component resistance ( tires ) , Nor added wind resistance factor has been added as needed into to the equation. My proven trusty Moroso slide calculator is telling me that to hit 146 mph you need 700 Hp and a 2900 lb car regardless of gearing.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 11-14-2023 at 10:55 AM. |
Stan
I'm very curious in this also as I run 4.11 gear and would like to drop to 3.90 gear to lower the rpm through the traps. I run a 29" tire and I would like to go back to the 28" tire. Dropping down tire size and gear would probably net same results? Thoughts
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. |
4.1:1 - 29" - 6500 RPM - 136.77 MPH 3.9:1 - 28" - 6500 RPM - 138.83 MPH 3.9:1 - 28" - 6405 RPM - 136.78 MPH 3.9:1 - 27.58" - 6500 RPM - 136.75 MPH Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
I run a 3.90 gear and changing from a 29" tire to a 28" tire had no effect on ET. I can't remember if there was any difference in rpm going across the line, but there was no change in converter slip..
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
Thank you Stan and AG. I appreciate the info.
Decided to leave the 4.10 gears in. The calculator's say with current comb and slip I should cross the line at 138 at 7000 rpms. That is my limiter setting. I think 138 should be good enough for 9.6's. I don't want to give up the 60' times.
So in the spring I will remove 350lbs, put the 1050 back on, remove the exhaust and run it all out and see where I am at rpm wise. |
Many years ago I did a computer simulation of a Pro Stock motorcycle run. Everything match up perfect. But to me something was off. The owner/crew chief/engine builder posted on a forum that I also posted on and had helped me for some information about the motorcycle. I said the only way I got everything to agree is to run out of RPM before the finish line. He laughed and said me too. He was willing to give a little MPH up for a better et.
Stan
Tire dia growth, with all that tire rpm ought change a 28" to 29" after 100' or so.
I always ran a 3:73:1 gear for my best results.
I tried 4:56:1 then 4:10:1 and got my best ET and MPH with the 3:73:1 this was a long time ago and not as fast as the car is now. GT |
