Old 11-06-2023, 11:56 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Finally - some (Cameo) white stuff...
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following 3 Users Say Thank You to pontiacstogo For This Useful Post:
  #122
Old 11-09-2023, 11:10 PM
Getting closer...
Parts waiting to be fitted to the car;
Core support and front wheelhouses are off the car being prepped and painted - then reassembly can begin.
Peter
The Following 4 Users Say Thank You to pontiacstogo For This Useful Post:
  #123
Old 11-22-2023, 09:28 PM
Reassembly progressing slowly;
Peter
  #124
Old 11-23-2023, 12:20 AM
Looks really good
Old 11-23-2023, 10:51 AM
chuckies76ta's Avatar
Looks beautiful.. Car will be brand new when done. I would remove that big rubber under the hood when done on the cowl. Let the hot engine air escape in the hot summer months.
950 Quickfuel.
  #126
Old 11-23-2023, 11:14 PM
Bumpers painted - should be going on today;
Peter
  #127
Old 11-23-2023, 11:29 PM
Originally Posted by chuckies76ta View Post
...I would remove that big rubber under the hood when done on the cowl. Let the hot engine air escape in the hot summer months.
nope - that keeps the hot air and engine smell from getting into the cabin via the cowl vent.
  #128
Old 11-23-2023, 11:55 PM
Looks like a very expensive renovation...
  #129
Old 11-24-2023, 10:54 AM
What engine smell? This is a Pontiac engine!! LoL
Seriously, I removed mine when I restored the car some 15 years ago.. Drive the car in summer months with the windows down anyway. There is no engine smell that I've ever noticed. Just a preference that's all.
950 Quickfuel.
  #130
Old 11-24-2023, 01:11 PM
Wow those bumpers look flawless...did you have any cracks before?
Old 11-24-2023, 02:29 PM
jhein's Avatar
jhein jhein is offline
Looks like high quality work. Did you do anything with the motor?
  #132
Old 11-24-2023, 03:12 PM
KS circutguy's Avatar
Beautiful.
  #133
Old 11-24-2023, 08:16 PM
My car was always a 10 footer and there were minor stress cracks on the corners both front and rear. The front bumper had a split through one of the bumperettes that was not very visible, but required repair to be nice. I know there was a good number of hours getting the rear bumper looking like it does now.
Peter
  #134
Old 11-24-2023, 08:27 PM
When I first bought the car (20+ years ago) I replaced exhaust manifold gaskets, timing chain, belts, hoses, plugs, filters and water pump. I had Cliff rebuild the original quadrajet.
Other than regular maintenance since then (oil, plugs, filters etc.) it's not had any major work done to it and as far as I can tell, it has never been out of the car. It's only left me stranded once, and that was when the HEI module died. I bought some parts before the move; new reproduction plug wires, 'correct' radiator hoses, tower clamps, washer bottle, belts and radiator overflow bottle. I'll fit all of that stuff once the car is home - I also have a rebuild kit for the OEM Hurst shifter that I need to install.
It runs really well, but the engine has 70K miles on it now, so it could probably do to come out and have a freshen up at some point - but (hopefully) not for a little while.
Peter
The Following User Says Thank You to pontiacstogo For This Useful Post:
  #135
Old 11-24-2023, 09:25 PM
Every GM I have owned has those seals, even my 1966 442.
  #136
Old 11-27-2023, 12:45 AM
Front bumper, header panel, lower valance, spoiler and fender flares all fitted;
And I just have to throw this out there - I hate dealing with fender flare welting.
Peter
  #137
Old 11-27-2023, 11:24 AM
Tempest's Avatar
Tempest Tempest is offline
Thank you for sharing the pics and your 'experience' with us.
This will truly be better than new when completed, absolutely amazing.
  #138
Old 11-27-2023, 11:38 AM
Your car is really turning out beautiful.
Although it has been a long and winding road , at least the shop you chose is delivering fantastic results.
  #139
Old 11-28-2023, 12:00 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I'm impressed with the degree of access the panel shop is giving you obviously on a regular basis. All too often some shops start quoting public liability restrictions not to allow you in too close to your car without a shop employee hanging over you.
They clearly are a "car guys" type of shop doing multiple (and top quality) restorations. I can see a Cadillac Eldorado, Jaguar, an early Dodge, Chev etc in various pictures as you document the restoration trail on your car.
I'd say it looks like a good, well run and friendly shop.
Ian
To laugh at men of sense is the privilege of fools.
The Following User Says Thank You to Heybuck For This Useful Post:
  #140
Old 11-28-2023, 08:09 AM
That front end looks beautiful.. Fit and finish better than factory.
950 Quickfuel.
