Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-02-2023, 01:10 PM
68hotbird 68hotbird is offline
Default 467 Stroker for sale fresh build
1972 988 400 block cleaned, baked and shot blasted, bored and honed with torque plates at ballos precision machine. Brc flat top forged pistons with plasma moly rings, Eagle 4340 forged I beam connecting rods 6.800 length, eagle cast steel crank, melling m54ds oil pump blueprinted and check ball modifications done, rotating assembly balanced, new power bond balance, and SFI flex plate, 6x heads ported and flowed by the legendary Jim Hand himself with flow sheets included. 1.6 ratio full roller rocker arms, comp XR288HR cam with erson morel lifters, trick flow .080 wall pushrods, Rollmaster billtet 9 keyway timing set, cam degreed to 106 ICL, MSD high torque starter, GMB High flow aluminum water pump with cast impeller and plate clearanced to the impeller. Edelbrock performer RPM intake with 800 CFM Quadrajet tuned and built for this combo with parts and receipt from Cliff Ruggles. Carter high performance mechanical fuel pump. I can do a couple different distributor options with this engine. Asking $8900 serious inquires only. Engine will be run on my break in stand and I can video or leave on the stand for buyer to see it running.
P.S. If the flopper sees this ad I don't need your useless comments about my Jim Hand ported heads. Thanks in advance!!!
Old 12-02-2023, 01:55 PM
Default Photos
Here are a few pics of the build
ID:	624206   Click image for larger version
ID:	624207   Click image for larger version
ID:	624208   Click image for larger version
ID:	624209   Click image for larger version
Old 12-02-2023, 01:57 PM
Default more photos
more pics
ID:	624211   Click image for larger version
Old 12-02-2023, 02:24 PM
VCho455's Avatar
VCho455 VCho455 is offline
Where might this engine be located?
Old 12-02-2023, 09:19 PM
Default stroker
engine is in Western Virginia near Roanoke.
Old 12-03-2023, 09:39 AM
gman005's Avatar
gman005 gman005 is offline
compression?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 12-03-2023, 10:56 AM
ponjohn's Avatar
ponjohn ponjohn is offline
How much power do you think it should make?
Old 12-03-2023, 11:04 AM
Default Compression/Power
heads are 6X-4 at about 92cc's which makes compression 9.6-1. I had these heads on a very similar short block in my brothers car with the Holley terminator X fuel injection system. Based on the times the car ran and the fuel consumption from the fuel graphs the engine made about 440HP and that was with a speedmaster efi intake that was of poor quality at best.
The Following User Says Thank You to 68hotbird For This Useful Post:
