Old 12-19-2023, 04:30 PM
Matman Matman is offline
Default Cam help
Hello all I’m new to the forum I’m building a 10-1 406 with butler prepared Edelbrock unported d port heads with a 72cc chamber short block will have forged rods and dss forged pistons edelbrock dual plain intake going in a 65 gto stick car I’m having a difficult time deciding on a cam shaft definitely going roller had originally been thinking about the xr276hr till I’ve seen posts on here about them being a pooch. Butler recommended their similar custom grind with a 112 Ls angle I’m looking for something that’s lopy at idle I’m just wondering if anyone has used this cam in a 400 and if it has a tame idle or no or can someone recommend me another grind that will fit my preference thanks.
Old 12-19-2023, 06:14 PM
steve25 steve25 is online now
If your planing on putting just the base line performer intake on those better flowing D port heads then you’ll be leaving some 25 hp on the table.
Knowing weather or not your running headers will need to be known to make a intelligent cam pick for your 400.
Old 12-19-2023, 07:34 PM
PDC PDC is offline
Been down this road with the Butler prepped E-Heads. Difference in cost between letting them inspect and assemble ‘unported’ heads with better valves and dual springs vs the cost of what they call their ‘290 cfm’ D-ports just isn’t worth saving. If you are paying them to inspect and assemble the heads with good stainless valves and dual springs for your cam selection, then toss the comparatively small amt of extra $$ and just get their ‘290’ heads. The exhaust port on the box-stock Eddy D-port is surprisingly stingy at 160. After porting to their ‘290’ level, my Butler prepped Eddy D-ports flowed 300/210.
Agree 1,000% on the suggestion to stay away from the std ‘Performer’ intake. Been there, done that. Far better potential and performance with a well-prepped stock intake. Or go RPM and drop the comparatively small amt on a drop base kit for your shaker or air cleaner base.
Virtually all negative reports on the Comp 276 roller cam are in regard to its use in 455s and 460+ stroker builds. Seat timing is pretty stingy for the .050 numbers. Buts it’s like likely much better suited to a 406. Butler’s 230/236 grind on a 112* LSA would be great in your E-headed 406 where the same cam on a 110* LSA would be on the small and tight side of things for a larger displacement build.
Very eager to hear how this build turns out!
The Following 2 Users Say Thank You to PDC For This Useful Post:
Old 12-19-2023, 07:36 PM
JB Eng Wis JB Eng Wis is offline
LOPY IDLE....406ci..... 10:1 comp .... Edelbrock D port
may I suggest Howards Hyd Roller #418005-09 its there smallest Rattler cam.
and I would use 1.65 rocker arms, if your springs can handle .583" of valve lift.
The Following User Says Thank You to JB Eng Wis For This Useful Post:
Old 12-19-2023, 08:12 PM
Thanks for the replies I’m sorry I didn’t specify I do have the performer rpm manifold and a set of Doug’s headers. I basically am just purchasing butlers builder kit for the heads it does come with better valves and springs matched to my cam but I’ll be doing the assembly.
Old 12-19-2023, 08:56 PM
Thank you Steve I do have the performer rpm manifold and a set of Doug’s headers.
Old 12-19-2023, 11:16 PM
KSZR KSZR is offline
How much more power with stock E D ports on a 400 vs big valve iron? All other things equal?
Old 12-20-2023, 07:30 AM
With stock iron heads running a .550” lift hydro roller you could make 420 Hp with a well thought out street 400 cid motor, take that same 400 short block and bolt on the D port E heads and then 490 to 500 hp should be under the control of your right foot.
Old 12-20-2023, 07:32 AM
Does Edelbrock offer those D ports in 72 CC version
Old 12-20-2023, 09:02 AM
Yes sir.
Old 12-20-2023, 11:28 AM
Stan Weiss's Avatar
When using the same lobes. As you widen the LSA you will reduce overlap and will have less lopy idle.
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 12-20-2023, 11:35 AM
srmmmm's Avatar
srmmmm srmmmm is offline
I used the Comp XE276HR in a 350 block bored .060 over with Butler's 4.25" stroker kit with Ross flat top pistons. 1.5 Ratio rockers. Calculated CR 9.3
6X-4 heads, Torker I intake, Buick GS455 Stage-II Quadrajet, MSD billet distributer at 34 degrees total advance, Hedman headers.
442 Lb Ft@4300 and 453 Hp@5600
Idle: https://www.youtube.com/watch?v=nxDtH_76piU
Best dyno pull after adjustments: https://www.youtube.com/watch?v=cfso2r9udv8
Still needs some on the road tweaking for better spillover to secondaries.
The Following 3 Users Say Thank You to srmmmm For This Useful Post:
Old 12-20-2023, 01:35 PM
napster's Avatar
napster napster is offline
Matman,
Just putting this information out there and my opinion.
I have a 1970 T/A with a 433CID engine with RAIV heads. The cam is a in the attachment. Engine uses RAIV exhaust manifolds with 2.45 outlet into 2.5 inch pipes. Total 31 degrees of timing all in by 3,500 RPM.
I would use this cam in a 406 with e-Heads. That's just me. Here is what the cam sounds like in a 433. Makes you wonder what the lope would be in a 406.
https://www.youtube.com/watch?v=BAFVExVbLXY
Boss made the video, but that is my car I am backing out.
Now, I do have a '78 with a 406 with 6X#4 heads. It has the cam in the second attachment. Here is what it sounds like. Has Doug's headers with 2.5 inch pipes. Total timing is 32 degrees all in by 3,000 RPM
https://www.youtube.com/watch?v=oP91rZkA84Y
The '70 T/a Has a HR with @ 050 numbers of 230/236 in a 433. LSA is 112.
The '78 T/A has a flat-Tappet with @.50 of 230/236 in a 406. LSA is 110.
Pick your poison.
ID:	625324   Click image for larger version
Name:	Cam Card For Snowman.jpg
The Following User Says Thank You to napster For This Useful Post:
Old 12-20-2023, 05:40 PM
Thumbs up
Originally Posted by napster View Post
Matman,
Pick your poison.
You sir have a beautiful pair of hot rods. I was originally going after the xr276hr but butler advised against it with the 110 love sep. I had my eye on the one in your blue car and I see it is butlers grind with the 112 lobe sep I think I might give that one a try I’m just afraid the next step down won’t suit me and your 433 is what I’m after I do understand it will be rowdier in the 400 with less cubes but think it would be right up my ally your don’t happen to know what intake center it’s installed at do you.
The Following User Says Thank You to Matman For This Useful Post:
Old 12-21-2023, 01:27 AM
blueghoast's Avatar
I used that cam thats in his 433 in a customers 400 with allum d-port
head's sugested from KRE I was a little hesitant but that little 400 run
like a wicked 455. I was impressed with it.
it's in a 67 firebird and runs like a bat out of h-ll if ya know what I mean.
That's a great selection for a cam in a 400.
GT
The Following 2 Users Say Thank You to blueghoast For This Useful Post:
Old 12-21-2023, 12:02 PM
napster's Avatar
Matman,
The intake centerline in the blue car is installed at 106 degrees not the 108 on the cam card.
Thanks for the comment on the cars.
Jim
Old 12-21-2023, 05:01 PM
Matman,
Jim
Sweet thank you.
Old 12-21-2023, 10:33 PM
Tim Corcoran's Avatar
Your 406 will make some serious power with this cam. May be a great match for your combo
Lunati Voodoo Hydraulic Roller. Serious street/race cam, very healthy idle quality. ;Advertised Duration (Int/Exh): 294/302 ;Duration @ .050 (Int/Exh): 243/251 ;Gross Valve Lift (Int/Exh): .560/.565 ;LSA/ICL: 110/106 ;Valve Lash (Int/Exh)
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
