TH400 Reid Case
Wondering if anyone has a TH400 Reid Transmission case sitting on there bench or can Identify these two ports for me. Thanks.
My friend at JW says the rear port is for the rear servo, nothing for you on the front as theirs and Reid case does not have that port. Must be a new design
Dave Polichena |
The Following User Says Thank You to Dave Polichena For This Useful Post: | ||
Ok Thank you. So the other port has to be the front servo as both ports are on the same side. Next time I have it apart I will defiantly make some notes.
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 01-12-2024 at 05:29 AM. |
