Old 01-15-2024, 05:01 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
Got the driver door skin on and door installed. Also started on the body bushings. We all know how fun those are!
ID:	626617   Click image for larger version
ID:	626618   Click image for larger version
ID:	626619   Click image for larger version
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #42
Old 01-16-2024, 05:50 PM
The car gained 1/2" of height with the new body bushings. Those old ones were cooked.
Next up, inner and outter tail panel replacement.
1987 Grand National
  #43
Old 01-20-2024, 04:57 PM
Hood totally stripped, and my tail panel and driver quarter pieces came in today.
ID:	626865   Click image for larger version
ID:	626866   Click image for larger version
ID:	626867   Click image for larger version
ID:	626868   Click image for larger version
1987 Grand National
  #44
Old 01-22-2024, 04:58 PM
Getting ready to tackle the tail panel and the driver side rear rail. Already have a replacement rail from a 78 parts car, so it'll be all original steel underneath.
ID:	626952   Click image for larger version
1987 Grand National
  #45
Old 01-24-2024, 04:06 PM
Have begun masking for etching primer. Running the heat in the winter creates moisture, so rather than keep sanding the metal down, into primer it goes.
Also grabbed the replacement rear rail from a parts car. Can't be original GM steel!
ID:	627123   Click image for larger version
ID:	627124   Click image for larger version
1987 Grand National
  #46
Old 01-25-2024, 06:18 PM
Got the car shot in etching primer today.
ID:	627220   Click image for larger version
1987 Grand National
  #47
Old 03-13-2024, 11:39 AM
Some updates. Floors are going in, and driver side inner wheel housing and quarter are getting patched up. You should never be able to tell someone was in there when it's done.
ID:	630312   Click image for larger version
ID:	630313   Click image for larger version
ID:	630314   Click image for larger version
ID:	630315   Click image for larger version
1987 Grand National
  #48
Old 03-15-2024, 05:50 PM
Rocker and quarter panel going back together:
1987 Grand National
  #49
Old 04-21-2024, 02:58 PM
Starting on the quarter and tail panel...
ID:	632421   Click image for larger version
ID:	632422   Click image for larger version
ID:	632423   Click image for larger version
1987 Grand National
  #50
Old 06-18-2024, 01:57 PM
Quarter almost fully mounted....
1987 Grand National
  #51
Old 06-18-2024, 05:37 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Looks like you did what we did on my Y88. Repop rear body panel fuel opening is not the same as the original. Looks like you cut it off down under that area and only replaced that section. Good call.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #52
Old 06-19-2024, 10:56 AM
Yup, I find it much easier to section the tail panel and repair only what's needed. Plus doing it this way allowed me to keep the upper half in place, so when the quarter was removed, I know the replacement quarter will go back in the same place, without having to worry about the tail panel alignment.
1987 Grand National
  #53
Old 07-11-2024, 10:55 AM
Making progress!
ID:	636641   Click image for larger version
ID:	636642   Click image for larger version
ID:	636643   Click image for larger version
1987 Grand National
