Old 01-23-2024, 09:32 PM
ID67goat's Avatar
ID67goat ID67goat is offline
My balanced rotating assembly did not have any balancing info included and was found to be out 9 grams at the front and 12 grams at the rear.
Also to note, all the new “neutral balance” parts were not much better… balancer was out 6 grams while the flywheel was out 12 grams, and pressure plate out 7 grams.
This was from a short block kit that was supposed to be ready to assemble purchased about 20 years ago.
After this I don’t trust that any assembly is ready to run and properly balanced.
  #42
Old 01-23-2024, 10:07 PM
grivera's Avatar
grivera grivera is offline
What vendor?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
  #43
Old 01-24-2024, 01:48 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
thanks for posting that vicgto. what pistons did eagle offer you with their rods and crankshaft out of curiosity.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
  #44
Old 01-24-2024, 01:59 AM
Schurkey Schurkey is offline
Originally Posted by Formulas View Post
I will say if I was to buy a single sourced balanced rotating assy I would expect to get a package that meets or exceeds OEM specs
OEM-specs were nothing to brag about. Buicks were goofy as all get-out. I have heard--but not confirmed--that Mopar was sloppy about balance.
The only source I know of says that 1970 Pontiac engines were balanced to "within 1/2 inch-ounces".
9:47 of this video--just after the audio comes back.
https://www.youtube.com/watch?v=9LuXf6gJ-jg
A half-ounce is about 20 grams. Fine for a grocery-getter. Maybe not adequate for anything that gets run to higher RPM on a semi-regular basis.
  #45
Old 01-24-2024, 10:58 AM
vicgto vicgto is offline
Pistons are forged JE/SRP
1972 GTO
468 2 Bolt Main w/Eagle rotating assy
SD Ported 295 KRE D Ports 10.8 CR
OF Hydraulic roller w/ 1.65 stainless rockers
Performer RPM Intake
Holley 3310 780 Vacuum Secondary
TH400 with 10" Continental Convertor
8.2 BOP 4 pinion 10 Bolt with 3.36 gears
11.428/118.95/1.618
The Following User Says Thank You to vicgto For This Useful Post:
