14x7" steel wheels
I have a set of four 1969 'IF' coded 14x7" steel wheels;
I have been collecting 14x7" GM wheels for some time, it took me a while to put this set together. I would prefer to deal locally, and in person. Asking $750usd for the set. Actual wheels pictured. Single cap not included.
Are all the date codes the same? Ship to 62563?
Drive it ! 69 Trans Am coupe 70 Trans Am 76 SE 455 hardtop 87 GTA 89 Turbo TA 02 CETA Convert |
Sorry for my delay in replying, I have had some trouble figuring out why these IF wheels seem to normally not adhere to conventional dating rules.
Short answer, no this is not a date coded set. The long answer is that one of these is a Kelsey Hayes wheel, the other three are Norris Industries wheels, of which two are a pair. Only recently did I come across some information about 1968 calendar year wheels having the date code done differently. Kelsey Hayes: K18_10 /\ 18_IF; October 18th 1968. Norris #1: Inside of rim: 14X7 JJ NT K 8 (logo) outside of rim: IF stamped right of the valve stem; 2_1_8* on outer edge roughly across from the valve stem * = to me this doesn't make sense. Norris #2 & 3: Inside of rim: 14X7 JJ NT I 8 (logo) P outside of rim: IF stamped right of the valve stem; 20_09_8 on outer edge roughly across from the valve stem
Are these still for sale? Do you have the date codes?
I still have them - I'd have to figure out where they are buried.
The date codes are listed and pictured above.
Wheels
Got any cl dated 2 22 of 70 or earlier. I misplaced 2 at dad's house
CL's show up occasionally on yenko.net, or more often over on nastyz28.com
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
