Old 01-11-2024, 04:53 PM
geeteeohguy's Avatar
Originally Posted by chiphead View Post
I've been reviewing the whole front end job and I think this is gonna be a sticking point. How do I get the upper control arm bolts out with the engine in place? Check out how close the bolts are to the headers, one pic for each side.
How would you guys get this loose?
Loosen the nut, and install another nut or two to protect the threads and buzz it with an air chisel with a punch bit and the bolts will pop out easily. The splines are not that deep. Just did this on an original '66 GTO that had NEVER had the arms off since new. Piece of cake. You don't even need a straight shot. The vibration will buzz it out. Click image for larger version
Jeff
  #62
Old 01-12-2024, 04:58 PM
chiphead's Avatar
chiphead chiphead is offline
OK, I'll give that a shot. Hopefully they give up the fight....
What about spring compressors? I've got the one shown below. Last time I used it, I ran it through the upper shock mount and compressed spring against the spring pocket in the frame to get it off the LCA. Is that still good shop practice?
https://www.powerbuilt.com/products/...rng-compressor
  #63
Old 01-13-2024, 04:01 PM
I never use compressors with A bodies. Just jack up the lower arm and compress the spring that way. It is dangerous, though, so you need to keep out of the line of fire and make sure it's all the way in the pockets and clocked right in the frame.
Jeff
  #64
Old 01-23-2024, 12:59 AM
chiphead's Avatar
Here's the latest progress! Got the driver' side put together. Global west uppers and lowers with 1/2" taller upper balljoint. Does everything look put together the right way?
Still need to tighten the tie rod end and install the shock. The swaybar is on BO, I called GW and they're supposed to ship me a 1 1/4 bar in place of the 1 1/18".
On to the other side!
ID:	626990   Click image for larger version
The Following User Says Thank You to chiphead For This Useful Post:
  #65
Old 01-23-2024, 10:19 AM
In some situations, the upper control arm bump stop needs to be trimmed or shorter. It can limit travel.
Otherwise it all looks good!
  #66
Old 01-23-2024, 10:59 AM
JLMounce JLMounce is offline
Looks good! There's just something about new and shiny suspension pieces against the crusty weathering of an unrestored car!
-Jason
1969 Pontiac Firebird
The Following 3 Users Say Thank You to JLMounce For This Useful Post:
  #67
Old 01-30-2024, 01:00 AM
chiphead's Avatar
Got it all together and on the ground tonight. The static ride height looks almost the same as it was with the drag springs. GW did say they intend for the LCA to be parallel with the ground, and it is. Shocks look to be about 1/2" way in their travel, which is correct. As long as the ride isn't harsh I'll be happy.
The only thing I did special was I swapped to 1/2" taller upper balljoints and had them install the 702 offset shafts. The driver side had no shims and I couldn't tell what was going on. Can I use the recommended alignment specs or do you guys have modified specs? GW instructions say:
Caster driver side: 5 degrees positive
Caster pass side: 5.5 degrees positive
Camber: 1/2 degrees negative both sides
Toe 1/32 per side, up to 3/32 total
The sway bar ends have a bolt, collar, jam nut and heim joint at the bottom. How do you set those, there were no instructions?
  #68
Old 01-30-2024, 08:05 AM
My understanding is yes, you would still use the same specs.
The sway bar ends should be parallel to the ground like the lower control arms. In some cases, people like to load one side or the other, but parallel to the ground would still be the starting point.
  #69
Old 01-30-2024, 10:59 AM
Use the GW alignment specs they gave you, that's a decent setup. If you want to, you can get rid of the road crown adjustment on the passenger side caster. You'll have to content with any road crowns you drive on, but turn in will be more even in each direction.
-Jason
  #70
Old 01-30-2024, 11:16 AM
I too ignore the road crown settings as well. I prefer to steer to compensate for road irregularities.
  #71
Old 01-30-2024, 11:19 AM
I had a new alignment done on my bird last summer and did remove the road crown adjustment. I didn't notice that much difference in day to day driving.
I was also able to achieve a bit more than 6* of caster each side at about 3/4 of a degree of negative camber. Turn in improved dramatically. Actually feels like about 75 lbs was taken off the nose of the car.
-Jason
  #72
Old 02-06-2024, 12:00 AM
chiphead's Avatar
How much steering angle is typically lost when converting to the tubular LCAs? The steering arm stops hit the LCAs and it looks like I've lost some turning radius. Do the GW steering arms give better turning radius? Can the stock pieces be modified?
And this may be a stupid question, but will the single piston disc brakes fit inside a 15" wheel? Looks like it's awful close to this weld pie cutter. Due to budget constraints, I'm likely going to go to wider 15" pro stars for the time being. I've got 3.5 inches from the bead lip to the outer tie rod. Everything else is farther away with this 205/75-15 on a 4 or 5 inch rim.
Check the pics. The first one shows the wheel cranked over to the stop. The second is the passenger side view from behind the wheel.
ID:	628021   Click image for larger version
  #73
Old 02-06-2024, 08:17 AM
Hm, I guess it depends on the LCAs, but I've never found there was a loss in steering. Except a long time ago with Fatman Fab ones, and think maybe the CPP ones, but would have to check.
On the calipers, guess it depends on which 15" wheels you're using. If you have room, you could use a spacer.
  #74
Old 02-06-2024, 11:24 AM
The A body steering stops are supposed to hit the lower control arms. Any difference there would be related to size difference of aftermarket lower arm to the factory lower arm. It's possible you may have gained or lost a tiny amount.
You can cut that steering stop off to gain some additional steer. You just have to know that you've done it and make sure you're not always cranking on the wheel past its limits.
I have a remanufactured box in my bird that does not have internal stops like the F-body boxes are supposed to. As a result there's no steering stop in the system. It hasn't caused any issues for me, other than the ability to put the tire on the frame rails and high steering angles.
-Jason
  #75
Old 02-06-2024, 01:03 PM
As an example:
(pics attached)
ID:	628046   Click image for larger version
  #76
Old 02-09-2024, 11:36 PM
kpbrown31 kpbrown31 is offline
I went with Rare Parts. Customer service was great as well when I had a question or two on install.
  #77
Old 02-13-2024, 01:51 PM
chiphead's Avatar
Just wanted to follow up after the alignment. The car drives much better! Doesn't wallow or bottom out turning on/off driveways, the tires don't drag the fenders, the steering wheel wants to return to center upon corner exit. The body lean on corner entry is much better. The steering and front suspension feels much more planted. Ride height is about exactly the same, but the dynamics are very different. So thanks guys!
  #78
Old 02-13-2024, 01:52 PM
Sounds like it's starting to come together!
-Jason
  #79
Old 02-13-2024, 03:10 PM
67drake's Avatar
67drake 67drake is offline
Ordered my GTO centerlink. Supposed to be here this week, but need to do 100 other things before I get to it.
‘55 Catalina
  #80
Old 02-15-2024, 04:29 PM
67drake's Avatar
Center link got here today. I saw at least one other member in this thread liked the same one. Might be awhile till it gets put in though. I got this from Summit-
https://www.summitracing.com/parts/p.../gto/year/1968
‘55 Catalina
