Old 02-10-2024, 11:20 PM
tom s tom s is offline
Rebuilt a Carter AFB,Hung my new engine on the run stand.Tom
  #262
Old 02-12-2024, 10:54 AM
BILL BOWMAN1's Avatar
Catalina- pass side A arms , new bushings installed. Gonna spend a couple days doing a back yard restoration, cleaning the 60 years off gunk off the chassis, and slather on some flat black.
Then turn car around and start other side(short on space).
  #263
Old 02-14-2024, 01:12 PM
Flat black brushed on, plenty good for a driver.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #264
Old 02-14-2024, 09:43 PM
67drake's Avatar
67drake 67drake is offline
Pulled LeMans distributor to send off for rebuilding and convert back to points, ditching this old Pertronix set up.
‘55 Catalina
  #265
Old 02-14-2024, 10:51 PM
Verdoro 68's Avatar
Did the Pertronix give you trouble? I seem to be the only one that's had good luck with those things.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #266
Old 02-15-2024, 12:32 AM
67drake's Avatar
I’ll know when I get the distributor back in and running. I have an erratic idle and stalling problem that gave me fits last summer. Replaced the carb, checked for vacuum leaks, ect ,still does it. Let a couple of other gear heads in my area go over it, and it’s been a head scratcher. A few people mentioned they had weird things like this happen with their Pertronix, so going to give that a try.
‘55 Catalina
  #267
Old 02-16-2024, 01:08 PM
Gastiresandoil's Avatar
Made a new hose holder
The Following 7 Users Say Thank You to Gastiresandoil For This Useful Post:
  #268
Old 02-16-2024, 01:53 PM
nas t eh nas t eh is offline
Got the tach working. I have a pertronix 3 and was worried about connecting the tach lead to the neg on the coil. I had incorrect info that the tach could be damaged by the multi spark feature.
But that is not true and in my cars case I didn’t need to add a resistor that is sometimes required for correct function of the tach.
Now I get too see how long the Pertronix functions before I get stranded like so many other have.
73 T/A 455, 4speed
  #269
Old 02-16-2024, 05:15 PM
capital idea...stealing 💡
Old 02-16-2024, 06:54 PM
OG68 OG68 is offline
I installed a Pertronix 3 on my 70 El Camino. No problems for the three years before I sold the car. I had an old SW tach (1965) with sending unit that worked just fine with the P3. (Tach is going back into my 68)
Old 02-17-2024, 10:22 AM
FirebirdHank's Avatar
Hey, I have one of those! When I got my used 15" wheels I had them all cleaned up and painted when I found that one of them had some rounding of the holes. What do you do with a pretty but non usable Ralley II?
Just a heads up, you are missing a couple of lug nuts.
  #272
Old 02-20-2024, 03:42 PM
Yes, I know there are two missing lug nuts, but my trailer tire carrier only came with provisions for 3 lugs. My rally is also painted an incorrect color as well.
  #273
Old 02-20-2024, 09:58 PM
4dblnkldude's Avatar
I fixed a little intake o ring leak on the 81. I took off the intake and was a little more liberal with the right stuff.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
  #274
Old 02-22-2024, 08:45 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is online now
New battery today. Topped off the tank & took it for a drive
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following 2 Users Say Thank You to OCMDGTO For This Useful Post:
  #275
Old 02-23-2024, 01:51 AM
Verdoro 68's Avatar
I took advantage of the dry weather and ran some errands in the T/A, then took the '68 down to open shop night at my son's school. I was hoping to do some more tinkering on the brakes but all the bays were full. It was fun seeing the shop kids drool over it and shout "noooo waaaay!" when my son got in to drive it home. He definitely got some cool points.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #276
Old 02-23-2024, 03:42 AM
Verdoro 68's Avatar
Forgot the pic...rolled over 19,000 miles in the Comp T/A while I was out today. It came to me with 16,700 in 2022 so I'm not exactly racking up the miles, but it's getting driven regularly. It apparently had a mere 500 miles put on in it in the 10 years prior to my ownership.
Since the tape player is fixed I rocked a little STP Purple while motoring around.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #277
Old 02-23-2024, 08:00 AM
In the works.. What a dirty miserable job, but rewarding.
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #278
Old 02-23-2024, 01:02 PM
full tank of gas what is stopping you...lol
[/QUOTE]
Old 02-23-2024, 01:05 PM
KS circutguy's Avatar
They seemed to be always problematic.
Points are a no brainer to fix on the side of the road.
Electronic your SOL.
The Following User Says Thank You to KS circutguy For This Useful Post:
  #280
Old 02-23-2024, 03:26 PM
jhein's Avatar
jhein jhein is offline
I could swap a HEI module faster than points on the side of the road. But, that's me. Maybe if your a points master it's the opposite.
Also, whenever anyone complains about HEI it usually seems to be Pertronix. I have a DUI and i've searched around and haven't really found many, if any, problems.
