Old 02-23-2024, 03:49 PM
KS circutguy's Avatar
I could swap a HEI module faster than points on the side of the road. But, that's me. Maybe if your a points master it's the opposite.
Also, whenever anyone complains about HEI it usually seems to be Pertronix. I have a DUI and i've searched around and haven't really found many, if any, problems.
In my old speed shop install - sales days almost every pertronix failed early on.
We were the east coast jobber for speed equipment including circle track stuff.
Auto Finishers Speed and Custom.
We stopped selling them and always sold MSD, magnetic trigger.
DUI are solid as well magnetic triggers,Pertronix are hall effect.
But cross country you still can't beat points and a carb.
  #282
Old 02-23-2024, 04:29 PM
jhein's Avatar
jhein jhein is offline
Just did a quick look and it seems like Pertronix sells both big and small cap distributors that can be either Hall or magnetic. Not sure why they have both. I haven't found anything on the Pertronix website yet that talks about it. On the Summit site they tell you if it's Hall vs magnetic, Pertronix doesn't even mention it is the specs on their site at all. The DUIs all seem to be magnetic. Original GM HEI were also magnetic, correct?
  #283
Old 02-23-2024, 04:58 PM
yep
Also the Mallory units were always failing,
they were Hall Effect as well.
  #284
Old 02-24-2024, 01:00 AM
VCho455's Avatar
VCho455 VCho455 is offline
Picked up the motor for my Firebird from the machine shop. Pretty stoked about it. Lots of pieces of the puzzle are coming together on the bird.
ID:	629257   Click image for larger version
ID:	629258   Click image for larger version
ID:	629259   Click image for larger version
The Following 5 Users Say Thank You to VCho455 For This Useful Post:
  #285
Old 02-24-2024, 09:50 AM
4dblnkldude's Avatar
I am going to put an exhaust system on my 81 TA today. The car is almost ready for a test cruise!
The Following User Says Thank You to 4dblnkldude For This Useful Post:
  #286
Old 02-24-2024, 01:17 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Today Nothing!
I did put the battery tender on in two weeks ago!
I bought 10 wix oil filters from rock auto.
The wifes kitcen up grade has taken what frre time I have this witer!
The Following User Says Thank You to gtokid1968 For This Useful Post:
  #287
Old 02-24-2024, 01:28 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is online now
Default Unboxed next project
Well next project has arrived.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following 3 Users Say Thank You to 68 Firebird For This Useful Post:
  #288
Old 02-24-2024, 01:39 PM
Thumbs up
Who did you have do the machine work?
  #289
Old 02-24-2024, 02:20 PM
VCho455's Avatar
Somers Automotive Machine. We've used Archie almost exclusively for over 20 years for machine work. (Did my OHC 6) We have him do the machine work and we assemble them ourselves. Once he's done with the heads we'll have the short block ready and then we'll have it dynoed at his shop.
He's a bit grumpy but the work is always on time and done right. He has a lot of regular customers who race for points so sometimes it may take a bit longer but he lets you know up front how long to expect.
The Following 2 Users Say Thank You to VCho455 For This Useful Post:
  #290
Old 02-24-2024, 06:29 PM
BILL BOWMAN1's Avatar
Progress, hope to start assembly Monday.
Then turn car around and start on driver side.
This tread has at least gotten me off my butt.
The Following 3 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #291
Old 02-24-2024, 07:32 PM
tom s tom s is offline
Went to a car show early AM,came home and did more work on my engine on the run stand.Getting closer to doing breakin.Tom
The Following 4 Users Say Thank You to tom s For This Useful Post:
  #292
Old 02-24-2024, 10:26 PM
Red face
Nothing.
Distracted with another project.
I’m building this chassis in the bed of my truck because it’s the only place I have room to do it.
ID:	629306   Click image for larger version
ID:	629307   Click image for larger version
ID:	629308   Click image for larger version
ID:	629309   Click image for larger version
The Following 5 Users Say Thank You to b-man For This Useful Post:
  #293
Old 02-25-2024, 02:26 AM
Verdoro 68's Avatar
Great weather today so I pulled both cars out and did some tinkering. Everyone seemed to have their old iron out around town. I saw a couple Mustang converts, a '69 FB convert and a '70 Super Bee while running around.
Came home and readjusted the back brakes on the '68 and did one more bleed. Futzed with the brake pedal switch and realized I've had the bracket in the wrong spot for the last 20 years which allowed me to adjust the pedal lower which in turn took a ton of slack out of the pedal. Pulled the old speedo cable out, which melted on the exhaust, out only to realize I ordered one that's too short. D'oh.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #294
Old 02-25-2024, 02:04 PM
carcrazy carcrazy is offline
Did a little buffing on the passenger side quarter of my 62. Plan on doing a little cleaning on the interior parts for my 67 GTO a little later today.
  #295
Old 02-25-2024, 03:43 PM
67drake's Avatar
67drake 67drake is online now
Nothing yet. But I was in Florida visiting kids/grandkids all week, and had parts for all 3 of my older cars on order that arrived. Now unboxing, and it’s close to 60 here in SW Wisconsin, so have the overhead door open while out here. First time since last fall.
‘55 Catalina
  #296
Old 02-25-2024, 04:11 PM
More work on the run stand.Tom
  #297
Old 02-25-2024, 05:01 PM
Trying to sort out a possible overheat issue. The OEM temp gauge shows the car overheating - but no symtoms.
No overflow, smell, etc. The OBD2 connector is not sending any signal - once I sort that out then I can read the ECM and see what the computers temp sender says.
One bite at a time I guess...
  #298
Old 02-25-2024, 05:22 PM
Mr Twister's Avatar
Started putting the Torqstorm supercharger on my 400 on the test stand.
The Following User Says Thank You to Mr Twister For This Useful Post:
  #299
Old 02-25-2024, 06:48 PM
Threw a battery in this yesterday and took it for a drive. And yes... I installed the hold down after I took the pic.
  #300
Old 02-25-2024, 07:07 PM
Got more work done on the run stand.Getting close.
ID:	629341   Click image for larger version
