Old 04-02-2024, 08:51 PM
65madgoat's Avatar
Default Opinions on 400 build: 4" crank 434 or 4.25" crank 461
I have this good .030 over 1968 400 block sitting around begging to be built.
Already have some old style 325cfm round port 87cc E-heads and Torker II intake.
Going in either a 1st gen or 2nd gen f-body that will see lots of street duty but also about ~6 autocross and track (road course) days a year.
Having had a 4.25" stroke 461, been flirting with trying a 4" stroke crank in this block just to perhaps try something different and rev some.
Will be forged crank and rods, roller cam, hydraulic roller lifters. ~10:1 CR.
Love to hear what I can expect from a 4" stroked 400 vs the more commonly seen 461 build. Plus and minuses for the application. Cam I should consider etc. Thanks in advance.
Old 04-03-2024, 05:59 AM
When you boil everything down to the syrup and A/B two different cid motors using the same heads you find that hp produced is independent of cid.
That said a 4.00" stroke motor will hold onto peak hp numbers longer due to less friction an also will rev faster which is a big plus in the acceleration game.
A 4.00" stroke motor tuned well will still make you enough torque to annilate your rear tires at will at most any rpm.
I would take full advantage of having Aluminum heads and get your compression up to 10.5 minimum .
Old 04-03-2024, 06:53 AM
napster's Avatar
napster napster is offline
I understand the idea of something different. I have my share of 461's. I went with the 433 RA IV in my '70. 4 inch stroke forged SCAT crank etc... I love it. Recently had to change the reproduction RA IV intake manifold with a real deal RA IV intake. The repro wasn't lining up properly and had two major vacuum leaks. The real RA IV intake lines up so much better. My mechanic thinks the intake cost me 10 to 15 HP when the engine was dyno'd. It was a pure bottleneck. Cam is a Butler grind (see below). Compression is a tick above 10:1.
https://www.youtube.com/watch?v=AXveB8zehOw
Also upgraded the lifters to the new Comp Cam Evolution. Very quiet as opposed to what you hear in the video.
Used exhaust manifolds with the 2.45 inch outlet. Figured the HP was 460 before the intake change now I would say it is 470-475.
The Following 2 Users Say Thank You to napster For This Useful Post:
Old 04-03-2024, 08:34 AM
grivera's Avatar
grivera grivera is online now
That’s a beautiful ride, Napster! What idle RPM and have you ran it at the track ?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
Old 04-03-2024, 09:12 AM
What length pushrods did you end up with with those lifters/ helping a buddy build a RAIV head 455 using them.
Old 04-03-2024, 10:01 AM
Stan Weiss's Avatar
Do you have a dyno sheet that you can post?
Stan
Pontiac Pump Gas List
Old 04-03-2024, 10:42 AM
JLMounce JLMounce is offline
If the car is being autocrossed, I would absolutely go with the 4" stroke. You'll be able to manage off corner acceleration a bit easier without the grunt the added stroke is going to give you at lower RPM's. Greater RPM potential will help you as well.
-Jason
1969 Pontiac Firebird
The Following 3 Users Say Thank You to JLMounce For This Useful Post:
Old 04-03-2024, 11:12 AM
napster's Avatar
Thank you. Idles between 750 to 800RPM. Never raced. I don't trust myself with the stick. Might miss a shift and lose the engine. If it was automatic I might try it.
Old 04-03-2024, 11:21 AM
napster's Avatar
Use this as a guide. My mechanic started with 8.75 inch push rod and didn't like it. Ended up with 9.00 inch push rod with chrome molly 80 thousandth's (SP) wall. Rocker arms are rollers @ 1.65:1 ratio.
Hope this help especially with all the variables involved.
Old 04-03-2024, 11:27 AM
napster's Avatar
Stan
Stan,
This is what I have written down and the numbers are uncorrected. I guess the corrected numbers are 460 HP and 545 TQ before the intake change. Figure the HP went up 10 to 15 with the new real deal RA IV Intake.
The owner of the dyno my mechanic uses is a real Richard. That is why the numbers are uncorrected.
Old 04-03-2024, 12:07 PM
Stan Weiss's Avatar
Stan,
Thanks. I was just having a discussion with someone over on Yellow Bullet who only likes looking at uncorrected number .
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 04-03-2024, 12:17 PM
Thanks it gives me a starting point. I have a couple of different adjustables we are going to use when we mock it up in the next week or two. I told him to get the rockers he is going to use also as even same ratio different brands affects that a bunch.
I think my Comp HR-"S" ended up 8.75.
I have a 4.00 stroke 400 block build planned -decision is do i use my RAIVs or soem Speedmasters.
Old 04-03-2024, 02:19 PM
65madgoat's Avatar
This 4" crank in the blue 1970 Trans Am Ram Air IV engine is still using iron heads though -- correct? So not comparable to what I am planning to do.... Just what are your iron heads flowing?
Old 04-03-2024, 04:18 PM
napster's Avatar
Correct, the heads are cast Iron #614's. The heads are stock and not ported. Numbers I have read in books is 230 or 240 CFM. I remember reading in Rocky's book, Nunzi Romano, saw some of the 614's flow 250CFM. The heads on this engine have not been bench flowed under my ownership.
Old 04-03-2024, 04:30 PM
napster's Avatar
I have a 4.00 stroke 400 block build planned -decision is do i use my RAIVs or soem Speedmasters.[/QUOTE]
I would use the RAIV's. A 428 RAIV should have happened in 1969 and the LS1 Ram Air Super Duty would have been nice to see in 1970. Even a 1970 455 with a RAIV top end would work as well. Hemi who? What is an LS6?
If John D. was still Division Manager in '69 &'70 I think one of the versions above had a chance to come to Market.
Old 04-03-2024, 05:38 PM
At best on a calibrated bench stock RA4 heads flow 230 cfm @ .600”.
At .500” lift they flow about 225 cfm which is enough intake flow to make a potential 57.5 Hp per cylinder, or 463 hp.
Old 04-03-2024, 05:39 PM
65madgoat's Avatar
How about the 325cfm E-heads with just under .600 lift -- what is their power potential in a 434ci?
Old 04-03-2024, 06:29 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
That should get you 550 to 600 hp if all is good in your parts selection.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 04-03-2024, 07:34 PM
Is that 325 cfm taking place at only .600” ?
Old 04-03-2024, 09:07 PM
65madgoat's Avatar
Yes around 600 lift
