Old 04-11-2024, 03:34 PM
grd777 grd777 is offline
Default 7 blade clutch fan
when years did these come on the trans am ,can i install one on my 72 formula.my friend has on for sale
my has a/c
Old 04-12-2024, 08:45 AM
found this photo ,it is Bobs 1972 455 .did the 7 blades only come with the 455
Old 04-12-2024, 09:26 AM
78w72 78w72 is offline
my has a/c
Not sure of the exact year for them, but yes you can use one on a 72 or any other 70's pontiac if you want... I have one on my 72 with a 400/467 & mid 70's accessory brackets.
Old 04-12-2024, 03:41 PM
would this one be correct
ID:	631954   Click image for larger version
Old 04-12-2024, 04:08 PM
That "looks" like it will work if you are using the common mid 70's brackets, some earlier brkts may be different. Maybe someone else can confirm based on the part# of the fan but from my experience any 350-455 mid 70's 7 blade fan will work on most model cars including 2nd gen firebirds.
Also should be easy to test fit it, if it sits about half way in/out of the shroud it will work.
Old 04-12-2024, 04:50 PM
Held for Ransom's Avatar
That looks correct for the Firebird. Have him look for the stamping on the clutch mounting face. https://forums.maxperformanceinc.com...d.php?t=806240
So long, farewell.
Old 04-19-2024, 12:45 AM
unruhjonny's Avatar
I put one of these on my ‘73;
As I recall, I pulled it off a Ponti-yacht.
the biggest PITA was getting the mounting studs off the car donating the clutch fan - then installing them on the ‘73;
Radiators and knuckles don’t get along very well!
1970 Formula 400
