Old 04-29-2024, 12:55 PM
Unexpected rainstorm last Friday. Found out the hard way... wipers don't work.
  #462
Old 04-29-2024, 10:16 PM
Verdoro 68's Avatar
Attachment 632875
I got caught in a storm on the way home in the T/A a couple weeks ago only to remember that the car had it's original 1995 wiper blades. Fortunately I recently ceramic coated the glass so it wasn't too bad.
I had today off so I kept chipping away at the rear end project. Fabbed up some brake line brackets for the axle tubes and extended the 12 bolt brake line mount. The upper control arms were suppose to be here today, but they're MIA via FedEx which threw a wrench in my plans, but I got the rear in place anyway supported by the jack.
I'm still held up by the brake lines anyway. I ordered a set for a 12 bolt Chevelle, but I have a feeling they won't work with the Moser upper ears and I may be bending my own.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #463
Old 04-30-2024, 12:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Got the Tri-Powered '59 GMC out of the barn, dusted it off for a short ride.
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post:
  #464
Old 04-30-2024, 07:44 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Attachment 632875
RAINX!!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #465
Old 04-30-2024, 12:26 PM
Originally Posted by OCMDGTO View Post
RAINX!!
I already fixed them. Unplugged and cleaned the connections.
  #466
Old 04-30-2024, 04:33 PM
65 Lamnas's Avatar
Bought a barely used radiator from HISGTO, but I can't stand the look of a bright silver aluminum radiator. This thing was pretty highly polished on the tanks and sides. I scuffed the polished areas with some 220 grit, and then cleaned it with brake fluid. Now it looks much better to me...hard to believe t's the same unit. It cost me about $25 and less than an hour of my time to black it out. Much cheaper than having it anodized.
ID:	632942   Click image for larger version
ID:	632943   Click image for larger version
The Following 3 Users Say Thank You to 65 Lamnas For This Useful Post:
  #467
Old 04-30-2024, 04:34 PM
Radman's Avatar
Radman Radman is online now
I have been to busy working on the cars to post what i did to them.
Red car: 1. Replaced the 30 amp generator with one of the 90 amp Powe rMaster alternators that are in the 30 amp generator body. 2. Replaced the trunk and door lock, I was starting to have trouble with the key. 3. Replaced the old T3 headlights with the modern sealed beam that are still marked T3.
White car: 1. Raised the Tri-Power gas line feed farther from the engine. 2. Changed the shut-off valves at the gas tank from 1/4 to 6AN valves. Hopefully that will cure my fuel starvation at the big end of the strip. 3. Door lock on the drivers side kept flopping part way out of the door. Replaced the lock securing clip inside the door.
Working on a new windshield for the red car.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
The Following 2 Users Say Thank You to Radman For This Useful Post:
  #468
Old 04-30-2024, 04:52 PM
Verdoro 68's Avatar
Looks good! Did the same with my Cold Case.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #469
Old 04-30-2024, 05:15 PM
form74's Avatar
form74 form74 is offline
Power wash the engine bay may be paint tomorrow the roadworthy rescues version 🤔
ID:	632948   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 4 Users Say Thank You to form74 For This Useful Post:
  #470
Old 05-03-2024, 09:44 PM
67drake's Avatar
67drake 67drake is offline
Finally got one of the Pontiac’s out!
Got my Mercury that I did the engine rebuild on drivable now. So pulled it out and swapped positions in the garage with the ‘63 LeMans.
Lemans is running great since I ditched the Pertronix and worked on the ignition over the winter. It’s still a detonation machine with the high compression ‘69 engine with unknown Comp cam.s camshaft. I believe next winters project is going to be going over that engine, and see just what grind cam is in there in favor of a wide lobe separation factory type grind.
Anyway, with my sixteen year old helping me out in the garage so much lately, I let him take the LeMans out by himself for the first time.
‘55 Catalina
The Following 4 Users Say Thank You to 67drake For This Useful Post:
  #471
Old 05-03-2024, 11:04 PM
Great reward dad 👌
  #472
Old 05-03-2024, 11:23 PM
67drake's Avatar
Great reward dad 👌
That was AFTER a lecture on how bad detonation is for an engine. I was 16 once too ya know!
Told him to keep his heavy foot out of it. The GTO is set up for beating on, the LeMans with the stock transaxle, and detonation prone cam,not so much.
‘55 Catalina
  #473
Old 05-04-2024, 12:19 AM
65 Lamnas's Avatar
Got the Q-jet back together after refinishing. Made a deal for a HSD intake.....not sure yet what to do with it.....it's excellent....brand new even.....no box but obviously never used.
Going to dyno the engine with 2 different intakes, and wondering if I should make it 3.
Ported '72 HO, Ported RPM, wondering if I should port this HSD or no cuz it's new? Maybe I'll find a nice untouched used or mint one and port THAT. Will be interesting to see numbers regarding intake swaps.
ID:	633159   Click image for larger version
  #474
Old 05-04-2024, 01:50 PM
BILL BOWMAN1's Avatar
Painted some new bumper brackets for my new chrome plated bumpers . Ordered new bumper bolts as well.
ID:	633175   Click image for larger version
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #475
Old 05-04-2024, 04:15 PM
Test rotation
ID:	633182   Click image for larger version
  #476
Old 05-04-2024, 04:45 PM
Jeff Hamlin's Avatar
Thumbs up
Changed the oil and got in some car time & dinner.
The Following 4 Users Say Thank You to Jeff Hamlin For This Useful Post:
  #477
Old 05-05-2024, 12:47 AM
Verdoro 68's Avatar
Installed new brake lines, bled the brakes. Happy that the Chevelle brake lines fit no problem with a little modification of the brake line bracket. Put the car back on the ground and got the pinion angle in the ballpark by adjusting the upper control arms. Just waiting on the new driveshaft and I should be ready to roll.
ID:	633205   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #478
Old 05-05-2024, 09:03 AM
Got up early, got that crappy fiberglass bumper off, need to remove that filler panel and nose and repaint.
  #479
Old 05-05-2024, 12:06 PM
She is not happy with me today!! Supposed to be just the bumper!
  #480
Old 05-05-2024, 04:35 PM
Stripping the black paint off the grills and going with the shiny look that B man did with his. Tedious job delicate aluminum.
