Old 02-27-2024, 10:58 AM
sperry67 sperry67 is offline
Default 1981 Turbo T/A
My wife and I acquired her dad's car after he passed away ~2 years ago. He was 2nd owner and car had been stored for 35 years. ~58,000 miles. Interior was re-done last winter, drove it a little bit last summer, a few car shows and cruise nights. This winter did carb and turbo rebuild and cleaned up under the hood a bit.
ID:	629432   Click image for larger version
The Following 2 Users Say Thank You to sperry67 For This Useful Post:
Old 02-27-2024, 12:02 PM
Formulabruce's Avatar
Wow, this car looks super original under the hood, thats rare these days. Have fun !
" Long may we DRIVE !"
Old 02-27-2024, 12:42 PM
78w72 78w72 is offline
Nice 301T! Looks like a bigger downpipe, any other mods?
These cars get a bad rep mainly from people that dont or didnt know how to work on them, but they are going up in value and some people like the 301/T for cruising/MPG.
I have a lower mile 81 pace car that is 99% stock and when tuned right with simple mods like removing the catalytic converter and open exhaust its faster than the mid to later 70's 400/455 T/A's. And with other basic mods they can run in the mid to upper 13's, a few more mods but still stock bottom end they can go into the 12's!
Old 02-27-2024, 03:14 PM
Nice really original look!
Old 02-27-2024, 04:53 PM
Mods so far..... Yes, went with the 2.5" downpipe, cat delete, 2.5" to the Y pipe for now, but will most likely continue the 2.5" all the way back w/ muffler delete.
Just had carb rebuilt as well as a standard upgraded turbo rebuild. EGR delete, air/smog pump disconnected (but still in place, for now). All new vac lines, some cleaning and some paint while it was all apart.
The complete interior was re-done last winter, will have to get some pics and post them.
The Following User Says Thank You to sperry67 For This Useful Post:
Old 02-27-2024, 05:52 PM
Sounds like it should run pretty good, what psi does the turbo run at?
Mine is just EGR delete, gutted the smog pump but still there as a pulley and for looks. most emission lines and solenoids are unhooked. Had the heads rebuilt with a good 3 angle valve job milled just for clean up, still has stock turbo set at 10-10.5psi, also stock down pipe but had no other exhaust for some test & tune runs, has mufflers now.
Old 02-27-2024, 05:58 PM
Good Question!!! Not sure yet as I just got it back together after the carb & turbo rebuilds recently and have not had it out yet. Still too much salt on the roads up here in the northeast.
Old 05-02-2024, 12:46 PM
KSZR KSZR is online now
Do you hear any detonation with 10psi?
I'm at 7-8 after bending my wastegate bracket(TTA advice). Now it runs so good with the carb rebuilt I'm going to bend it back and try 9-10.
Old 05-02-2024, 01:36 PM
I do get a slight pinging at WOT under full boost but none or not audible at 3/4-7/8 throttle or when the boost is under 8-9psi.
This is with normal 91 octane gas, havent tried 93 with 10% ethanol yet, but now that the car is full exhaust I dont usually do any WOT or high RPM runs on the street, its too nice of a low mile pace car to mess with racing or max boost, the test & tunes were just for fun to see what it would do, very happy with times that are almost 2 full seconds faster than recorded stock times with a professional driver... & mine is 99% stock still.
Old 05-03-2024, 07:35 PM
Now my check engine light is back on and idle is weird. Need to pull the code.
The Following User Says Thank You to KSZR For This Useful Post:
