Champ we have no GM dealerships in town and even if there were Parts dept wouldn't be open after 5PM or on weekends.
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
I see no mention of Decca ? They were 1 of the main 3 manufacturers forever… did they get gobbled up also? I was told NAPA changed from Johnson control to Decca last yr.? Is Decca now a part of company that bought Johnson Control? I’ve had very good service from NAPA Legands that were built by JC… Also (don’t hate on me) Motorcraft batteries have been the longest lasting battery I’ve ever seen for a long time now… also I have an O.E. AGM battery in our 2015 Acura that’s still doing fine. I also got 9yrs from OE battery in a 2009 G8 … also an AGM… maybe something to longer life from AGM batteries?
I mainly use XS Power AGM batteries. I've had them last 10+ years, amazingly light as well. I also had a Braille AGM that lasted about 12 years.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Honestly, I've had very good luck with car batteries. I've never had a battery die prematurely unless I did something to kill it. Back in the day I would only use Interstate batteries. That was decades ago. Since then I've used various brands. Most recently I was using O'Reilly Super Starts in the DDs. Those have been very reliable. When I got the TA though, I wanted a black color battery, that's when I started using Napa which have been good too. I'm probably going to switch to Napa for the DDs too just because they are good batteries and the people there are more friendly and seem technically better than my O'Reilly store for whatever that's worth.
And as was mentioned earlier, even though two batteries are made in the same facility, they're not necessarily made to the same specs.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
We also sold motorcraft, and hundreds of other popular manufactures products. My apologizes are in order. Lets not all forget most importantly battery made date codes,don't accept anything more than a few months old. I've seen them as old as 1yr. in some inventories.
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
Got 13 years out of Walmart battery for my mid 80's Toyota pickup. I hate going there and giving them my money but I needed a battery late at night so I gave in. This was for a truck I put less than 500 miles a year so it spent months between uses. I fully expected that battery to last no more than 5 years under those conditions.
Got 10 years out a Kirkland (Costco) battery in my 1999 Honda Accord. This was before Costco switched to Interstate. The factory battery lasted 7 years (Panasonic). The Interstate battery replacement is 8 years old now. Really, I never had a problem with a battery but I'm paranoid about running them down and never killed one yet. Not running them down and keeping it topped off with distilled water goes a long ways. Now that I have a 40x60 shop, I rotate a battery tender on them. I really should get rid of some vehicles now that I rarely drive much anymore. |
Video links were nice thanks.
Born on date, I don't buy old beer or new batteries that are actually old. I'm going to Antigravity battery for my GTO when I get it back. 8.5lbs, dead start safety feature and lasts pretty much 2x as long. Main issue is initial price and charging if needed. https://antigravitybatteries.com/pro...tive/ag-26-rs/
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
I'm not sure I would want a lithium battery in my car. They are very sensitive to charge rate, and will catch fire and burn.
I wouldnt use another Optima if you gave it to me.
and to think they have gone further downhill since i last used one 15 yrs ago
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
The cheapest battery you can find especially for classics that sit for a long time and a battery tender or if it sits somewhere that is not close to an outlet a cut off switch on the positive cable. I have had a Die Hard battery in the 79 truck for a good 15-20 years now and all I use is a cut-off switch. When it is really cold I might have to hook up the Gooloo jump pack to it but after that it starts every time. I have a cheap Walmart battery when they used to cost 40 dollars on Trans Am with a trickle charger and it is about 10 years old.
going bandit-Reynolds style |
I've been getting 7-13 years out of the 1 year Walmart batteries.
The 1 year Walmart I just replaced in my Acura was dated 2011 Its been in 3 different vehicles since I bought it. It was still useable for certain things so I kept it. The 1 year Walmart in my van is only 7 years old and has been in 2 different vehicles. The van doesn't get used as often and now that battery is getting flaky . After a week it needs a jump start. , it will still be useable for certain things too. But going to replace it. Been buying those for about 25-30 years when they were $35 Now they are $70 On the flip-side ,,, my friend went hollywood style and bought a 3year Walmart. 3.5 years it was done. The 1year Walmart just seems unbeatable by all measures. Normally I get 7-10 years out of them. 13 was a new record Last edited by Baron Von Zeppelin; 05-10-2024 at 03:03 PM. |
Do not buy a Diamond battery! I have one in my 2018 GMC truck that is my daily driver. I let it sit for 5 days while I was out of town with my wife. When I got home the truck motor would not even turn over. And, I have already replaced this battery once under warranty.
