Old 02-15-2024, 06:33 PM
unruhjonny's Avatar
Honorable mention:
  • F1) 1971 Front fender "Formula 400" script emblem; nearly identical to one-year 1970 part except that the 1971 part has the mounting stud locations changed from the 1970 badge (#483625); the two forward mounting studs have been spaced out further with the first stud being placed behind the "F", and the second stud being placed behind the "L".
  • F2) 1971 Front fender "Formula 350" script emblem; one year part cast as 1970-style “Formula 400” badge.
  • F3) 1971 Front fender "Formula 455" script emblem; one year part cast as 1970-style “Formula 400” badge.
  • F4) Front plastic valence; This was used on pre-production, and some very early model year cars; Listed in 1970 Firebird supplement, and master parts catalog; became regular production item for 1972 & 1973 model year Firebirds (but the service replacement was the steel setup).
  • F5) The rear spoiler was NOT an option for 1970; standard on Trans Am, not available on others.
  • F6) Some 1970 & 1971 base model Firebirds received the incorrect hard plastic Camaro arm rest (w/rubber pad) assembly on the correct Firebird door panel; this is hte part which is reproduced, and incorrectly listed as being correct by pretty much every vendor right now.
  • F7) rear seat back frame and seat bottoms are 1970-1973; metal spring construction with cotton and burlap construction for 70-73 - went to foam padded design for 1974
  • F8) Early second gen cars used yellow throttle return springs
  • F9) early cars use larger (read: longer) exterior door handles
  • F10) heater control lens on non-AC cars; 1970 reads “DE-ICE”, changed in 1972 to read “DEFROST”
  • F11) speedometers and gauge clusters are unique for 1970 through to early 1972 model year cars;
    These speedometers have a single small horizontal blue bright lamp indicator at the top, and a single red horizontal parking brake indicator at the bottom; the brake indicator has white stenciled “BRAKE” lettering so it can be seen when not illuminated; the bright indicator is near invisible when not illuminated.
    The 1970 fuel gauge has from empty to 1/4 tank colored red; 1971+ does not have any colored section near "E"
  • F12) Combination oil pressure & water temperature gauge for ‘Rally Gauge’ opted cars; center water temperature reading at twelve o-clock is 210 degrees for 1970 through to 1973, while latter (and service replacement) gauges read 220 degrees at twelve o-clock.
  • F13) Wiper switch; chrome edged button with “WASH” script in white on black background used for 1970 through to 1972; changed to “PUSH” for 1973.
  • F14) swaybars; it appears as though most 1970 model year Trans Am’s left the factory with the Formula specified sway bars installed; this may have been a supplier issue as the Trans Am was initially slated to have the same suspension as the Formula, but was changed just before the long lead press review; if it was a the supply problem, it seems to have been resolved before the end of the 1970 model year as late cars all appear to have had the right parts, and there are no documented 1971 model year Trans Am’s with the “wrong” bars.
  • F15) Base/Esprit/Formula dash insert; other than what was mentioned in point #C10, these dash inserts are actually made from a different press-formed piece with different indentations, and they all use unique gauge surrounds (rings) than 1973+ dash inserts.
  • F16) 1970 through to mid-1972 Trans Am hoods;
    a) Identified by two square-ish holes on the bottom leading edge - possibly as early as mid-1972 this changed to four holes.
    b) also identified by round holes on the drivers side in the structural bracing, while later hoods have oval shaped holes.
  • F17) 1970-1972 cars with ralley wheels used the same style lug nut used on 1967-1979 cars - they were a two piece chrome lugnut with a black plastic insert; service replacements were cast with the end hole covered, and black epoxy(?) which looked like hte older placstic cover.
  • F18) 1970-1972 non-A/C cars used chrome pull knobs for the vent controls; they became black for 1973.
  • F19) the dash pads for 1970 through 1972 Firebirds are a slightly different grain & texture than the 1973-1977 dash pads.
  • F20) Power trunk release button; aqua-green or green; this is a 1970-1974 part
    Green power Trunk button
  #422
Old 02-15-2024, 06:35 PM
unruhjonny's Avatar
1970 only paint/interior colors
Exterior:
(no example at this time)
exterior #10 'Polar white' ('69 & '71-'81 are #11 'Cameo white')
exterior #25 'Bermuda blue'
exterior #28 'Attol blue'/'Atoll blue'
exterior #45 'Palisade green'
exterior #47 'Verdoro green'
exterior #51 'Goldenrod yellow'
exterior #58 'Granada gold'
exterior #63 'Palomino copper'
exterior #65 'Carousel red'
Interior (colour comparisons):
vs
interior #201/211 'bright (metallic) blue vs darker (non-metallic) blue used 1971+
vs
interior #214 red vs toned down 'Sienna' used for 1971
Wheels
14x6" plain steel (std on base & Esprit w/E78-14 tire) = ‘AM’ 1970-1972
14x6" Rally II (optional on base & Esprit w/E78-14 tire) = ‘JO’ 1970-1972(?)
14x7" plain steel (std on Formula, optional on base or Esprit w/F78-14 or F70-14 tire) = ‘CL’
14x7" Rally II (optional on all except TA w/F78-14 or F70-14 tire) = ‘JS’
15x7" Rally II (optional on Formula; standard on Trans Am) = JW (1970 & early 1971)
400/4bbl numbers & codes
- Final year of high compression; essentially a carryover from late 1969 mechanicals, with only casting number revisions.
- All engines used 1969 style thermostat housings with 1970-only upper rad hoses.
Alternator:
#1100902 = w/o AC or rear window defogger
#1100903 = w/ AC or rear window defogger
#1100904 = w/ AC and rear window defogger
Starter:
#1108434 = 350
#1108435 = 400 w/o RA
#1108436 = 400 w/RA
http://www.wallaceracing.com/starter-numbers.htm
Exhaust manifolds:
L30/L65/L78 = 9796992(rh) / 9782810 or 480602 (lh)
(Note: the lh manifold on full sized cars used a center exit; 9796155)
L74 = 9799720 (rh) / 478140 (lh)
L67 = 9799721 (rh) / 478141 (lh)
Intake manifolds:
L30/L65 =
L78/L74 = 9799068
L67 = 9799084
Water pump:
all = 9799124
Timing chain housing:
all = 9796346
(Note: two font sizes of this casting have been observed)
400-4bbl engine/transmission combinations;
(block stamped code) / (cylinder head casting number) / (block casting number)
L78/auto = YS / 13 / 9799914
L78/manual = WT / 12 / 9799914
L74/auto = YZ / 12 / 9799914**
L74/manaul = WS / 12 / 9799914**
L67/auto = XP / 614 / 9799915*
L67/manual = WW / 614 / 9799915*
* = these started out as four bolt main '914 blocks, the end of the casting number was ground off, and re-stamped;
This number essentially denoted these as four bolt main short blocks with forged pistons ('914 blocks were assembled with cast pistons).
** = These are all four bolt main blocks;
Although PMD literature suggests that the '915 block was intended for RAIV engines, there are several documented RAIII engines being built with '915 blocks.
I believe that the non-RAIV '915 blocks are the exception, and were done to keep up with demand during production.
Four barrel carburetors:
L78/auto = 7040264; c/w 2 port metal vacuum break
L78/manual = 7040263; c/w 2 port metal vacuum break
L74 & L67/auto = 7040270; c/w yellow/black single port plastic vacuum break
L74 & L67/manual = 7040273; c/w yellow/black single port plastic vacuum break
California L78/auto = 7040564; c/w 2 port metal vacuum break
California L78/manual = 7040563; c/w 2 port metal vacuum break
California L74 & L67/auto = 7040570; c/w yellow/black single port plastic vacuum break
California L74 & L67/manual = 7040573; c/w yellow/black single port plastic vacuum break
400/4bbl distributors:
L78/auto = 111 1148
L78/manual = 111 1176
L74/auto = 111 2009
L74/manual = 111 2024
L67/auto & manual = 111 2013
Gauge cluster assemblies
ZA = base gauges
ZD = base gauges w/optional clock
ZE = rally gauges w/clock
ZF = rally gauges w/tach & clock
  #423
Old 02-16-2024, 12:09 AM
Formulabruce's Avatar
I will add, for 1970 only, The Lower "A" pillar was different than other years.
Most, if not all, have an added "Bump out" with a dimple to locate 2 Door switches.
Some cars came with dual door switches.
The reason is C2
  #424
Old 05-25-2024, 09:26 PM
unruhjonny's Avatar
this thread is always in the background of my mind, and I prefer to show examples instead of just text;
Can anyone tell me if this is 'Bermuda Blue'?
Because I don't recall seeing this hue on another 1970 Firebird.
https://www.hemmings.com/classifieds...1ac156ef962ef0
1970 Formula 400
  #425
Old 05-25-2024, 09:37 PM
unruhjonny's Avatar
1970 Formula 400; L78, M40, Light Blue
ID:	634290   Click image for larger version
ID:	634291   Click image for larger version
1970 Formula 400
  #426
Old 05-25-2024, 11:12 PM
That's not a factory color - looks like whoever painted it changed the color. From the paint visible in the trunk, my guess is it was originally Castillian Bronze (note this is a Van Nuys car, so that's not the red oxide e-coat, since they didn't apply that at VN in 1970).
  #427
Old 05-26-2024, 12:04 AM
turbo69bird's Avatar
So is it a 70 or 71 can you tell
960 HP @ 11 psi, 9.70 at 146.
  #428
Held for Ransom's Avatar
Agree.
So long, farewell.
  #429
Old 05-26-2024, 11:41 AM
added a couple extras
  #430
Old 05-26-2024, 12:06 PM
mlewisariz mlewisariz is offline
Seat headrests imply 1970
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
  #431
Old 05-26-2024, 01:12 PM
Having trouble adding these
ID:	634316   Click image for larger version
  #432
Old 05-26-2024, 08:14 PM
Trim tag from said car.
So long, farewell.
  #433
Old 05-26-2024, 08:37 PM
unruhjonny's Avatar
Thanks!
As it happens the gentleman called me(!);
I sent a note through the Hemmings listing (which required a phone number) saying I shared the listing, and that it would help his cause if he shared a picture of the cowl tag, or PHS (if he ran that).
He suggested it was Castillian Bronze and that the second owner did a repaint;
He seemed very forthright, and very friendly.
Apparently his first car was a ‘70 TA, and he’s selling this in the hopes of getting a TA.
Thanks for sharing the picture of the cowl tag - that confirms it was a Castillian Bronze car;
You guys are really sharp at seeing a tiny bit of the original paint in the truck - I missed that.
I made a passing comment about the added ram air stuff, and he thought it was all factory;
I can see the vacuum reservoir, which suggests it’s an L78 car - but I don’t know what he’s got the reservoir line going to..??
It’s a very nice looking car.
1970 Formula 400
  #434
Old 05-26-2024, 09:19 PM
71 Birds and Formulas had the fake grille on the fenders below the emblems.
And as mentioned appears to be low back 70 seats.
  #435
Old 05-26-2024, 09:24 PM
I can see the vacuum reservoir, which suggests it’s an L78 car - but I don’t know what he’s got the reservoir line going to..?.
Its a good representation of Bermuda Blue.
Has RA induction and RA exhaust - but #13 heads.
Most likely a YS engine.
  #436
Old 05-27-2024, 12:10 AM
It’s a little tricky, nose was fiberglass , seats were from herb Adams and were trans am racing series aluminum
seats originally Eckstrom told me they were trans am seats and I though what the heck is the difference trans am
Or formula . lol
I later found out it was trans am racing series seats
I’m
Not exactly sure if they went in when the car was first built by Stephen or after. I just know that herb came to CT and him
And Eckstrom went to lime rock park. He (Eckstrom) was also flown out to Pontiac to meet w Tom Nell that’s when they got involved in the RaV program , they already had the RAIv car and had the RaII car the year before.
Reason I ask about the year is because the car has been described by those who worked there as both 701/2 and 71 wasn’t sure if you guys who knew there year could tell
But what’s also tough about it is the car was updated a few times until I belive 73 season when they were bottled from the racing program because of an article that came
Out divulging factory involvement/ support in be racing program. Stephens thought they were playing it safe w the info and didn’t divulge nearly the support they had but apparently the factory was pissed as they took back some
Of their parts that were currently at diamond auto and told them they were out of the racing program
Eckstrom
(The driver and mechanic drive back to Stephens and quite on the spot. Apparently the owners son had given the info on the car not realizing how hush hush it was supposed to be.
Article was Rodder and super
Stock
Magazine by Joe oldham
Maybe Jan 72. Took a while for it to get back to the factory what exactly had happened though, I think .
The big issue was the info about the alluminum block and the intake Pontiac had supplied.
ID:	634337   Click image for larger version
ID:	634338   Click image for larger version
ID:	634339   Click image for larger version
  #437
Old 05-27-2024, 06:19 AM
No VIN in the car now?
  #438
Old 05-27-2024, 10:27 AM
unruhjonny's Avatar
wait, does this car still exist?
1970 Formula 400
  #439
Old 05-27-2024, 12:02 PM
I have accumulated most of the parts from the car over the years even the gauges etc.. I don’t have the body but I do have most of the info to recreate it or identify it if it was found
However it was supposed to have been crushed by a local metal scrap yard because the front sub frame and an arms etc had been extensively acid dipped and were paper thin. Real question is did they actually scrap it. ( who knows)
The RAV pro stock engine is currently in my RAIv firebird , where we believe it was at least tested at one point before the 70 body’s got there. my car also got the RAV style shift light tach at ( what I can best figure) the beginning of 70 race season .can tell because for a short time the tach changed colors in the pictures which coincides w them getting the V parts from Pontiac and changing it
The 70 body hadn’t been delivered yet, and had a glass front end so the tach went on my car instead of the pro stock car ( sadly it came off in 1978 and I don’t have it) .
I’d like to find one of the repros someone made (HOBI I believe )
Anyway the two drivers for Stephens say the body was a 70 and a half but the article says it was a 71 so I figured I’d put it out there to you guys for fun and see if you noticed any gel take signs on the back half . It’s hard because the car was also update every year earliest picture I know of w a date on it was August of 70 ! I will eventually recreate it as best I can from
All the info and parts that I have .
I grew up 1 block away from Stephens original Pontiac dealership and knew both of the drivers .my dad and who brother knew most of the guys who worked there and worked on the cars and some salesmen. I also bought my first bird from this dealership new. I used to draw pictures of these cars on my note books in school �� and we rode our bikes through the dealership making vroom vroom noises pretending to be driving them
The Following User Says Thank You to turbo69bird For This Useful Post:
  #440
Old 06-01-2024, 06:09 PM
Exterior code 67, Castilian bronze with interior code 217 deluxe sandalwood.
ID:	634570   Click image for larger version
ID:	634571   Click image for larger version
ID:	634572   Click image for larger version
