Our 69Z with deluxe interior comes factory with a pretty thick rubber trunk mat with a houndstooth design on it. I had to buy a new one, they are just over $100. Not a cheap trunk mat but very nice quality. |
They were an available accessory option for basically every model of every year.
Next time at a car show, lift up someones mat. More times than not, you will see some minor rust starting. |
The Following User Says Thank You to dhcarguy For This Useful Post: | ||
That was more of an issue back East and pretty commonly seen when I lived in Ohio.
Out here in Arizona not so much of a problem when you have dew points in the single digits and 15% humidity. The mats themselves disintegrate from decades of use while the trunk floor remains pristine. |
The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
Like the much thinner assembly line installed rubber mats, I don't like them. Just pulled in too many projects & parts cars from TX, OK, even from out in NM, where the thin rubber style mats were stuck to the trunk floor. Once the thin mat is carefully pulled up, there's a rust stain on the back of the mat, & at the very least minor rust pitting on the trunk floor. My '72 T/A had a thin trunk mat mat as part of DLX trim interior option. Unless I find a perfect used '72 mat & then go to the trouble of installing & removing it, I doubt the '72's trunk floor ever gets a mat again. Even after refinishing with epoxy primer & modern paint, I'm paranoid about condensation & rust.
this happened to my 67
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
There is a "technical" thing called capillary condensation that can bite you when two surfaces are in contact, but like Formulajones, if the RH is 10 or 15%, even that scenario is unlikely. Mike |
