Old 07-09-2024, 02:30 PM
arbys's Avatar
arbys arbys is offline
Default I'm second guessing myself or am I?
I set the adjustable lifters on my "66 with 326 HO. and am second guessing that I (77 years old) did them all correctly. Is there a quick way to check all of this?
Old 07-19-2024, 01:10 PM
Factory bottle neck studs and nuts or adjustable poly lock/crimped nuts?
Old 07-19-2024, 03:04 PM
arbys's Avatar
Adjustable polylocks. I finally ended up buying rocker arm oil deflecting clips and adjusted with the engine running. So glad that I did because now I feel that they are correctly adjusted.
Old 07-23-2024, 01:14 PM
Dick Boneske's Avatar
I agree. Set the hydraulic lifters with the engine running.
Very simple--adust the rocker nut until you hear clicking from that valve, then adjust the nut about 1/2 to 3/4 turn beyond where the noise stops. Lock the nut at that setting.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-24-2024, 03:39 PM
Another way if you don't have the clips is to cut a slot down the center of an old valve cover and adjust the rockers with a socket and extension through the slot.
