oil Pressure Regulator Valve
I have an oil leak from a crack in my accessory housing. I bought a used one and in the process of rebuilding it I noticed it is missing the oil pressure regulator valve; only the spring is under the nut. Are these available? Where can i get one? Any tips on getting the old bearing out of the housing?
Reach out to Rob Egbert (Woodland Motorsports)he should be able to help.
Here's his FB page for parts & services. https://www.facebook.com/profile.php?id=100063507821383
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
inside bushing puller like those used for motorcycles
will work for you
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
