Old 07-26-2024, 08:52 PM
DaleO's Avatar
DaleO DaleO is offline
Default I need a new timing chain cover
and there are a few options that I can see. Do you have a recommendation? Does anyone know if there are better than another one or are many just reboxed? I see Allstar, Pioneer, Edelbrock and Restoparts. I see vendors Ames, Year One, Summit, Jegs, Partsgeek, OPG. I want a bolt on, no required mods. My default is Ames but sometimes reproduction aren't so great for any of these sources and I want correct/perfect bolt on if I can.
Old 07-26-2024, 09:17 PM
tom s tom s is offline
Both good 8 bolt and 11 bolts are on the market now.Should have no issues.I would lean toward our sponsor if they have what you need.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 07-26-2024, 10:17 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I got mine from Ames. Perfect.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 07-26-2024, 11:23 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Get the crank seal from BOP engineering. the fel pro one sucks big time.
I am the Thread Killer!
The Following 2 Users Say Thank You to indymanjoe For This Useful Post:
Old 07-27-2024, 06:33 AM
Why do you need a new cover?
I have fixed some very sad ones in no more then 2 1/2 hours, even if the heater hose nipple is very pitted and you could do the same .
Old 07-27-2024, 12:20 PM
DaleO's Avatar
Well, I might not, I will inspect closer for other potential issues but I have some stripped threads and most "ugly" is the top bolt which is common with the alternator bracket where I have a bolt all the way thru with a nut/washer on the backside. Also, I really don't expect any corrosion issue but won't know until it comes off. I'm preparing for a cam swap.
Thank you Steve
