Old 07-26-2024, 01:30 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Fantastic job! Well done!
Go fast, see Elvis!
Old 07-26-2024, 03:11 PM
Good job!
Old 07-28-2024, 07:42 AM
aaronman aaronman is offline
Fantastic! It was a pleasure meeting you and your wife as well!
Old 07-28-2024, 09:25 AM
firechickenman's Avatar
firechickenman firechickenman is offline
Thanks guys!
It was great meeting you and Bill!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 07-29-2024, 11:52 AM
R 70 Judge's Avatar
Originally Posted by firechickenman View Post
Some of you may remember that I had a crankshaft failure at Norwalk last year. It was an 11:1 .035 over 455. OE block and crank, Eagle rods, SRP pistons, SD Performance 325 cfm CNC heads, Comp Street Roller cam 266/272 duration on a 110, right at .650 net lift, 4150 Northwind intake with a 2" tapered spacer/adapter and a 1050 Dominator. TH350 with a 10" PTC that flashes to 5000 and 3.73 gears, 275/60R15 ET Street Radials. It was a good running combo and I hated to loose the shortblock but that happens sometimes using a 50+ year old cast crank.
Moving forward I decided to go with an All Pontiac aluminum block, 4.350" Mahle pistons and rings, Molnar 6.8 rods and a Molnar 4.375" crank. It comes out to 520 ci and it has the same 11:1 compression as the 463. I used the same heads, cam, intake and carb. I got it together just in time to take it to Norwalk this year for it's first passes. Interesting that the bore/stroke ratio is the same for both engines. The aluminum block is supposed to be about 60 lbs lighter than an OE block but I added weight back to the car with motor plates, heavy trans bellhousing and remote oil filter system. The car should be within 10-20 lbs of what it was before.
I really didn't know what to expect on the track. I knew it was possible that it wouldn't pick up much if it did at all if the cam/heads were already maxed out on the 463. Anyway, the 2 time slips here show the fastest passes from last year and this year. This is with no carb tuning and conservative timing on the 520. Needless to say, I'm very happy with the results!
Outstanding results! How is the idle quality with that cam? Sounds like a great combination
James
1970 Trans Am
Old 07-29-2024, 01:10 PM
Thanks! I think it idles pretty good. Seems a little tamer than it did in the 463 but still pulls hard to 6500. Here's a video of it idling in gear at 1000 RPM: https://youtu.be/N4sn0RmPWKg?si=G5zARhziBhMY6B7x
Greg Weigart
The Following User Says Thank You to firechickenman For This Useful Post:
Old 08-02-2024, 09:09 AM
scott70's Avatar
scott70 scott70 is offline
It’s funny the things in life that make us happy. I would of been peeing my pants with joy over that improvement!
The Following User Says Thank You to scott70 For This Useful Post:
Old 08-02-2024, 10:17 AM
CraigG.'s Avatar
CraigG. CraigG. is offline
Congratulations!
What is the weight loss with the new block?
Old 08-02-2024, 01:15 PM
I was very pleased with the improvement and consistency not to mention no issues considering it was a new build. Luckily, there was no loss of bladder control!
Originally Posted by CraigG. View Post
Congratulations!
Thanks!
I haven't scaled the car since the changes, but I imagine it is within 20 lbs of the 3300 it was before since I added motor plates and a remote oil filter. The IAIIA block is supposed to be 138 lbs, OE blocks 195-205 lbs and IAII iron 245 lbs. My block weighed in at 127 lbs after machine work, drilling the deck and opening the oil drains in the valley. That is with the main caps installed.
Greg Weigart
