Old 08-24-2024, 06:23 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Default Oil filter options
Hey guys. I had headers installed recently and just went to change the oil filter and I don’t have the clearance between the header and the oil pan to get the filter out. Only way is to crush filter and that means I won’t get another one in there. I am using a standard wix 51258. I thought I recall there being another filter option that was a little more narrow, albeit longer? True or imagined?
Old 08-24-2024, 06:31 PM
tom s tom s is offline
Use the small LS style-size filter.Just change a little more often.Tom
Old 08-24-2024, 06:38 PM
Dragncar Dragncar is offline
You can run a K&P Filter, pretty small.
Old 08-24-2024, 06:43 PM
I can remember a friend in high school who had a Tri-Power 1966 GTO with a horrible set of headers like that.
We were in auto shop class and he couldn’t get his filter out either.
I suggested unbolting the filter adapter from the block.
It worked but it sucked.
Old 08-24-2024, 08:28 PM
soupman soupman is offline
The Baldwin B-31 is very short, only 3” tall.
Old 08-24-2024, 08:30 PM
Formulas's Avatar
Formulas Formulas is offline
STP Full length but skinny, less dia than mount
Old 08-24-2024, 08:37 PM
tooski tooski is offline
I went with b-man's suggestion of removing the adapter, several times. After the first couple, I installed studs into the block to make it easier. I finally went to a remote filter set up to make it really easy, and with a larger filter.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 08-24-2024, 09:30 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Pf61
Old 08-24-2024, 09:47 PM
Steve C. Steve C. is offline
And another to the list....
The NAPA 1045 (WIX part # 51045 ) which is a popular smaller filter.
Old information here:
Old 08-24-2024, 10:29 PM
Ok thanks for all the options guys. Will get some ordered
Old 08-25-2024, 03:28 AM
64speed's Avatar
64speed 64speed is offline
PBL25288 Purolator
Old 08-25-2024, 06:51 AM
steve25 steve25 is online now
All of you who have no concern about running a smaller more restrictive oil filter are nuts, pure flat out nuts!
Your all concerned with the life of your motors yet installing a smaller filter that will only serve to make the oil bypass open up more often is the exact OPPOSITE of what you should be doing and looking to change to keep your motor healthy.
If you not driving a pure factory stock show car then you should run a remote oil filter mount and run a 2 Qt filter on it, or even better yet two 2 Qt filters and then your having the added benefit of a oil cooler effect.
Old 08-25-2024, 08:43 AM
Those look SOOoo good hanging in the engine compartment,I’ll jump right on it!NOT!
The Following 5 Users Say Thank You to tom s For This Useful Post:
Old 08-25-2024, 09:58 AM
Jay S's Avatar
Jay S Jay S is offline
This is what I run in pontiacs with headers, even with the factory the oil bypass blocked, I have never seen a psi loss from the filtering.
Old 08-25-2024, 10:10 AM
Personally I run a remote filter set up because I have custom built headers on my F-body for additional ground clearance. It is hidden from view under the front fender.
When considering your oil system capacity keep in mind how much oil is in the lines to and from a remote mounted filter. On mine there is about 3/4 quart of oil.
Old 08-25-2024, 10:13 AM
Bosch works great.
Old 08-25-2024, 01:55 PM
Jay S's Avatar
My first choice on any Pontiac with headers is to get rid of the factory filter housing and tapping the block for NPT fittings, and hide an eternal filter. The problem though is when it is an after thought, and you realize the stock filter won’t fit. The engine is installed, and it is really too late to tap NPT lines into the block. The small filter I think is the next best option to that. If a filter adapter is used for a remote filter kit, often the fittings and lines get positioned pretty close to the headers, it creates more issues than it solves.
Old 08-25-2024, 03:17 PM
694.1 694.1 is offline
There is always the OHC 6
Filter is on the opposite side as the headers.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 08-25-2024, 03:53 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
LOL great point! ^^^^ the sacrifices we make to go faster!
I am the Thread Killer!
