Old 09-07-2024, 08:07 PM
Chiefkey Chiefkey is offline
Default Pontiac V8 Blueprint Drawings
Does anyone have of know where I could obtain copies of Pontiac V8 Engine "Blueprints" or dimensional drawings of blocks, heads, intakes, Etc. ?
Old 09-08-2024, 07:25 AM
steve25 steve25 is online now
No, but curious as to what ya building ?
Old 09-08-2024, 09:49 AM
i82much's Avatar
i82much i82much is offline
maybe a Pontiac V8?
Old 09-08-2024, 10:28 AM
tom s tom s is offline
I do.Have them from when I was trying to get a couple factory aluminum blocks machined.Tom
The Following 5 Users Say Thank You to tom s For This Useful Post:
Old 09-08-2024, 11:02 AM
Well since the V8 is two V4s in the same block then something out of the norm might be getting investigated.
Old 09-08-2024, 11:51 AM
zippy's Avatar
zippy zippy is offline
Or a V8 is 2 slant 4s in the same block LOL
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 09-09-2024, 12:07 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Kinda like two 194 Tempest engines put together...wait what?
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 09-09-2024, 05:05 PM
242177P's Avatar
242177P 242177P is offline
Orange block or blue?
Old 09-09-2024, 05:43 PM
unruhjonny's Avatar
Tom I am sending you an email about this - please check your inbox or junk folder!
Jonathan
1970 Formula 400
Old 02-07-2025, 12:20 PM
myfirstbird68 myfirstbird68 is offline
Default CAD
Hey there, new to the site so apologies if this repeating. I’m working with a fabricator to develop an adapter plate for a modern transmission (think 6L-10L) for my 1968 firebird. I wa going to do an LS swap in the thing as I won it in an auction. I get it home and it’s numbers matching. Nostalgia in me wants to keep the Pontiac engine but I still want to modernize. Oh, and the current trans is a powerglide. I’ve worked out the controller problem through upgrading to EFI, now it’s getting the adapter fabricated. To wit, I can send a bunch of parts to the CNC folks, or I can send drawings. Does anyone have CAD drawings of the Pontiac/BOP back of engine? Ideally I can nab the full suite of transmissions too.
I know I could just buy a TCI 6X , drop in a 4Lxx, or go a TH350 and gear vendors but I still wanna have some fun shoehorning a modern transmission on a vintage, albeit updated, engine.
Thanks!
Old 02-07-2025, 12:57 PM
My 409 buddy in Dallas Pat Lobb has 409 block blueprints that are as big as a conference table 4-5 feet long! He got from someone back in the day. It even had the codes for the letters used for "fitted blocks" and the different sized pistons.
I have a 455 block that has similar fitted piston letters on the deck.
Old 02-07-2025, 01:28 PM
If your pulling the original trans anyway….. make a template.
Old 02-07-2025, 01:37 PM
darbikrash darbikrash is offline
Thanks!
Before you go to the trouble of making one, give these guys a call on the chance that they already have one or can make one. All they make is engine/transmission adapters, and they have the hole patterns for just about everything so they could probably make one easily.
Although they don't specifically list the Pontiac V8, I'd be surprised if they didn't have the hole pattern. Worth a try.
https://www.kennedyeng.com/8-cylinder-engine-list
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 02-07-2025, 03:49 PM
Sirrotica's Avatar
The transmissions you refer to have a chevy bell pattern which is the same as a 4L80E. The adapters are rather cheap to go from a BOP engine bell pattern engine, to a chevy bell pattern transmission. No need to re-invent the wheel.
Link to Jegs: https://www.jegs.com/i/JEGS/555/60172/10002/-1
Many people don't know that the 2 lowest bolts, and the pilot dowel locations on chevy and BOP patterns are in exactly the same position. The upper bolts are the only ones that don't match up. The adapter I linked to matches the upper holes up, the 2 lower holes already match up and just require a bolt to pass through the adapter plate and screw into the block.
BTW, the original 2 speed transmission in your car isn't a powerglide, it's a turbine 300, many times mistakenly called a powerglide. The two transmissions share little, to no common parts.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 02-07-2025, 04:11 PM
spectramitch's Avatar
spectramitch spectramitch is offline
Im not sure if these years bolt patterns are the same as newer blocks but Im pretty sure I used these measurements to make a fixture to hold my 73 400 block.
ID:	647233   Click image for larger version
Old 02-07-2025, 05:27 PM
Yes to the above.
The ass end of a Pontiac block has never changed.
Old 02-07-2025, 05:50 PM
Yes to the above.
From 1964 and up this is true.
1955-1960 was different and 1961-1963 was different as well. These early engines used 7/16-14 bolts to attach the bellhousing until 1964 when they started using 3/8-16 hardware.
Pontiac didn’t finalize their design for a while after the inception of the V8, the same goes for cylinder head to intake bolt patterns (1955-1960 and 1961-1964) that were finalized in 1965.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 02-07-2025, 05:54 PM
Correct.
We had a guy on here who had the blueprints to make an adapter from early to later.
(Gavin I think)
I have a pdf of them and had them on my site. (probably still there if find the link)
