Old 09-15-2024, 05:58 PM
Held for Ransom's Avatar
Default Possible cause...
...of a collapsed upper radiator hose? Hose was replaced in 2012 when they got my 1973 Firebird Formula running again. Original radiator still, original cap. Was in normal shape after coming back from the show.
So long, farewell.
Old 09-15-2024, 06:01 PM
Cap may not be letting air back into the system when it cools down. Pulls a vacuum slightly on the system. I see it allot in the trucking industry
The Following 7 Users Say Thank You to chiefbigb For This Useful Post:
Old 09-15-2024, 06:09 PM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
I had the same issue when I purchased a repro cap from a well known Vendor.
Went to the chain autostore and bought a cap for a quarter of the price from the above vendor. No more collaped hose. It seems the repro cap isn't letting in air as stated by Chiefbigb.
Tom
Old 09-15-2024, 07:07 PM
steve25 steve25 is online now
Be sure to wipe out any crap from the sealing area that the rubber of the cap mates to otherwise even a good new cap might produce the same issue.
Old 09-15-2024, 08:43 PM
I was already thinking cap and checked it out. There was no build up. Rag turned black where wiped from cap though. So, that will probably be replaced.
So long, farewell.
Old 09-15-2024, 09:07 PM
Verdoro 68's Avatar
Interesting. I had this happen the other day and as it happens recently replaced the radiator cap with a new repro.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-15-2024, 10:16 PM
Verdero,
That is very interesting. I purchased mine a few years back.
When I compared the repro one to the chain store one I notice the little vent/check valve built into it seemed very tight compared to the other one. Maybe a flaw in design?
Tom
Old 09-16-2024, 12:02 AM
Verdoro 68's Avatar
This one is super tight and very hard to twist closed. I thought that was a good thing, but maybe not.
The hose hasn’t collapsed again since that one time, but I've been checking every time I drive it.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-16-2024, 03:39 AM
We've had several 'new' caps that didn't work correctly.
When you took the cap off, did the hose immediately return to its' normal shape?
Old 09-16-2024, 05:29 AM
I didn't take it off at the show, left in a collapsed shape. And was back in shape when I got home, even after the cool down.
So long, farewell.
Old 09-16-2024, 07:23 AM
I don't think there is a negative effect to the condition other than the visual side once the system has been run and air purged from the system
Old 09-16-2024, 08:02 AM
Half-Inch Stud Half-Inch Stud is online now
You figured good on the cap. Add more coolant. Run a catch can. Be happy.
Old 09-16-2024, 12:17 PM
Tim Corcoran's Avatar
It seems the rubber products coming from China are inferior and this has caused a multitude of problems in recent years, and may be related to radiator cap issues.
Tim Corcoran
Old 09-17-2024, 10:11 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
I would also check the hose going from the radiator to the overflow tank. Make sure it’s not collapsed or full of junk. Same goes for the tank. It all needs to be free flowing.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
The Following User Says Thank You to Holeshot71 For This Useful Post:
