Old 09-17-2024, 02:59 PM
i82much's Avatar
i82much i82much is offline
Default installing transfer slot restrictors
After installing transfer slot restrictors into a 4150 style carb, should I be able to push a drill bit through the restrictor all the way into the body of the carb so I can see the drill bit by looking down into the primaries?
Thought I read somewhere you could drill too far into the main body and I'm worried I may have done so ...
Old 09-17-2024, 06:25 PM
Formulas's Avatar
Formulas Formulas is offline
If you drilled where i think you did, straight across from lower IFR's in towards main body into primary bore? yeah not good
Old 09-17-2024, 06:31 PM
Are you seeing brass chips or aluminum from the drilling you did?
