Old 09-13-2024, 11:01 AM
aogmitch aogmitch is offline
Default Lost Brake and Turn Lights ‘66 GTO
Brake and turns stopped working the other day while driving. So far have checked fuses and tore apart column to check turn switch. All other lights/ electrical is working fine. Is there somewhere else I should be looking? Like stated, turn signals and brake lights are dead. Dash lights, headlights, park lights, interior lights all working.
Old 09-19-2024, 02:55 PM
spartazoo's Avatar
spartazoo spartazoo is offline
Try wiggling your ignition key. This happened to me and all it was is the key was out of sync. I still have to wiggle it into the right spot to get brake and turn lights to work.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 09-19-2024, 03:04 PM
Kenth's Avatar
Kenth Kenth is offline
I would suspect a malfunctional turn signal switch.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-19-2024, 09:44 PM
Use a voltmeter or test light and check out the system.
Old 09-19-2024, 10:18 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I know you said all other lights are working, but you didn't mention the tail lights. Have you checked the flasher unit on the fuse panel?
Old 09-20-2024, 10:23 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
You check the switch under the brake pedal?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60
The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60'
Old Yesterday, 04:04 PM
geeteeohguy's Avatar
Check the horseshoe connector block under the steering column. IIRC its the second wire in from the passenger side of the connector. I've had this same thing happen to me on a '65 GTO and a '66 GTO and both times, it was the bullet connector into the horseshoe shaped connector block under the column had backed out for the wire feeding the TS switch that also affects the brake lamps.
Jeff
