I will have the following parts for sale at the Pontiac Southern Nationals this coming Saturday in Frisco, Texas. Feel free to stop by and buy, buy, buy!
Bilstein Shocks front & rear - B6 Performance '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $300 BMR Suspension Front upper & lower DOM control arms '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $600 BMR Suspension Rear upper DOM control arms & axle housing bushings '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $100 BMR Suspension Rear control arm reinforcement braces '68-'72 GM A-body, '69-'72 GP/Monte Carlo New $100 BMR Suspension Coil springs - front & rear '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $200 BMR Suspension Rear sway bar - 1" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $120 UMI Performance Front sway bar - 1.25" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo Installed and removed $200 Tanks Inc Fuel tank straps & hardware '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $30 Holley Street HP 950 polished carburetor Universal 4150 square bore Used for engine break in $500 Holley Street Dominator intake manifold w/separated water neck Pontiac 326-455 Used $150 Doug Nash - Warrior Intake manifold w/separated water neck Pontiac 326-455 Used $300 CompCams Ultra Gold aluminum roller rockers - 1.52 ratio Pontiac 326-455 Installed never ran $400 Lunati Retro-fit hydraulic roller lifters Pontiac 326-455 Installed never ran $400 MSD Pro-Billet Ready-to-Run distributor w/vacuum advance Pontiac 326-455 Used for engine break in $400 PowerMaster XS Torque mini starter Pontiac 326-455 Used for engine break in $150 Ames Performance 68-72 GTO Ram Air d-port exhaust manifolds Pontiac 326-455 Used $260 GM 455 crankshaft Pontiac 455 Used $80 GM 455 crankshaft Pontiac 455 Used $80 GM 12-bolt axle assembly - Eaton posi, 3.42, forged axles '64-'72 GM A-body, '69-'72 GP/Monte Carlo Used <10,000 miles $1,500
'70 GP Model J 467 Butler ported Edelbrock D-ports Torker II intake with Holley Sniper 2 CompCams 236/242 hydraulic roller Tribal Tubes tri-y headers full 3" stainless exhaust TH400, 3.50 9" CurrieTrac, 245/35-20 Front, 275/35-20 Rear |
