Old 10-14-2024, 08:07 PM
dv657172's Avatar
dv657172 dv657172 is offline
Was scrolling through Franks Pontiac Parts and he had a pretty good selection of fans. May be worth a look.
Old 10-14-2024, 08:14 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Originally Posted by 64speed View Post
What vehicles should I be looking for to get the 19.5 inch fan
I've found several over the years on this site parts wanted section.
Old 10-14-2024, 08:22 PM
64speed's Avatar
64speed 64speed is offline
https://www.ebay.com/itm/28588459983...emis&media=SMS
How’s this?
Old 10-16-2024, 01:54 PM
64speed's Avatar
God fans are expensive LOL
Old 10-16-2024, 02:18 PM
Lol everything is expensive now
https://youtu.be/XqEydRRRwqE
Old 10-17-2024, 12:42 AM
Default 9796134 is the part number for the 19 1/2" fan blade we try to use.
It was used from 1969 to 1972 on GTOs and Firebirds. Maybe on 1968, too.
They were used on 1969 to 1972 Grand Prixs, too.
These move a TON of air.
Old 10-17-2024, 06:06 AM
The factory fan on Dad's 69 gto that he bought new is a 5 blade direct drive fan. Still have it stashed away. It's similar to the 7 blade direct drive mentioned early on in this thread I commented about that hole shot mentioned in post 12 but with only 5 blades.
Old 10-20-2024, 03:37 PM
Default One other thing to be aware of when choosing a fan blade.....
We just acquired a 1965 LeMans a few weeks ago.
It has factory AC and the factory 7-blade fan and clutch. And about fifteen more options.....
Anyway, I noticed that the fan blade had squared-off notches at the outer end of each blade.
Got looking a little closer and the notches are needed to clear the bolt on the end of the power steering pump shaft that retains the pulley.
I'm pretty sure that you've upgraded to the newer-style pump, so this might not be an issue on your build, but I wanted you to be aware of it.
Here's a thread on another board showing what I'm talking about:
https://www.gtoforum.com/threads/196...ptions.141672/
Name:	1965 7blade fan w notch.jpg
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 10-20-2024, 03:49 PM
64speed's Avatar
Thank you
Old 10-27-2024, 06:59 PM
2nd67GTO's Avatar
2nd67GTO 2nd67GTO is offline
As a side note and PSA;
If you're running the factory aluminum blade, steel hub style, check closely for stress fractures in the aluminum next to the hub. My original fan came apart driving. Luckily the blade that came off, went straight down and not thru the hood! Did take out the shroud as it came apart.
I found 2 more blades with fractures.
Hope this saves somebody from having to spend 4 hours cleaning under the hood.
If it's worth doing, it's worth overdoing!
In the works; 400 based 468 Stroker. 4 Bolt mains, Fully forged rotating assembly, KB flat top, custom ground Comp hydraulic roller, KRE 85cc, 310 CFM heads, FAST multi port EFI.
The Following 2 Users Say Thank You to 2nd67GTO For This Useful Post:
Old 03-23-2025, 02:14 PM
64speed's Avatar
Mod done and working
Old 03-23-2025, 10:03 PM
GtoFM's Avatar
GtoFM GtoFM is offline
2nd 67, thanks for the PSA, I ckd mine, NO stress cracks.
