Old 11-03-2024, 04:37 AM
dataway's Avatar
dataway dataway is offline
Default Shop Floor Vacuuming
Over the years I've found that I end up vacuuming my shop floor rather than sweeping, seems like sweeping just stirs up too much dust.
Anyone ever seen a hard floor nozzle for a shop vac about 24" wide? For my old shop a typical 10" or so nozzle was fine, but the new shop would take forever at that size. Usually I'm just picking up a heavy dust coating.
Been playing with the idea of making my own with PVC pipe and a 3D printed adapter.
Old 11-03-2024, 05:49 AM
propuckstopper propuckstopper is offline
I also vacuum my garage floor, as I put down an epoxy coating with a clear coat some years ago. I do a quick vacuum then a quick mop. Way less dust.
I have a central vacuum port in the garage, so I use that port with a long hose. I think the hose is 1 1/4 inches in diameter, and I use a 10 or 12 inch wide floor tool to get the job done.
The Following User Says Thank You to propuckstopper For This Useful Post:
Old 11-03-2024, 10:01 AM
besserspat besserspat is offline
I dont know let me ask my wife...
...just kiddin'
Peter
The Following User Says Thank You to besserspat For This Useful Post:
Old 11-03-2024, 11:28 AM
burd burd is offline
Shop vac makes 2, one with a brush, one with rollers. I have both. Both work well.
The Following 3 Users Say Thank You to burd For This Useful Post:
Old 11-03-2024, 11:58 AM
400 4spd.'s Avatar
I need the same type of vacuum for my shop. 24" would be perfect, lots of obstacles over 10,000 sq. ft.
The Following 2 Users Say Thank You to 400 4spd. For This Useful Post:
Old 11-04-2024, 12:52 AM
dataway's Avatar
The widest one I could find on the ShopVac site was 14", which is wider than most, but 18" would be better, and 24" would be great.
Old 11-04-2024, 01:22 AM
OG68 OG68 is offline
Nothing at McMaster Carr? Come on Data, I thought you owned stock there.
Old 11-04-2024, 01:28 AM
Redpiston Redpiston is offline
Just being a DA.
You could just get 3 or 4 ROOMBA'S with self unloading. Use the laser barricades to divide up the space.
The Following User Says Thank You to Redpiston For This Useful Post:
Old 11-04-2024, 04:04 AM
dataway's Avatar
OG, Hey Thanks! I haven't looked there yet!
Redpiston .. you know, that would probably work. And it could find all the small hardware I drop and lose. Would be an interesting, but probably expensive experiment.
I'm starting to think about slicing a piece of 2" pvc pipe in half long ways, drill a big hole in the middle and 3d print something to attach it to the hose. Maybe drill a bunch of 1/4" holes along a line on either side .. then slice it down the middle of holes so it doesn't "stick" to the floor.
Assuming McMaster doesn't have anything
Old 11-04-2024, 04:08 AM
dataway's Avatar
BAM!!
McMaster has one 20" wide!
https://www.mcmaster.com/63815T16/
The Following 4 Users Say Thank You to dataway For This Useful Post:
Old 11-04-2024, 04:36 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I just use our old demoted upright vacuum from the house. lol
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 11-04-2024, 05:20 PM
72projectbird's Avatar
I sweep it every now and then. I usually power wash the floors at least twice a year, which really cleans things up well.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-04-2024, 08:21 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I vacuumed my shop floor once. The dirt came back! You won't catch me doing that again!
The Following 3 Users Say Thank You to fyrffytr1 For This Useful Post:
Old 02-18-2025, 05:24 PM
dataway's Avatar
I solved my search for an affordable wide shop floor vacuum brush with my usual long way around.
I used the 14" wide shop vac squeegee, long broken, as the foundation for the project. I 3d printed some strips that would clip onto the attachment and have channels to accept some "strip brush" I found on McMaster. Glued the 3d printed clip-on "adapter strips" to the attachment, slide the strip brush into the channels, cut the ends to fit.
Works like a charm, but I do wish it was a few inches wider, but perhaps too wide would make it awkward to use.
ID:	647688   Click image for larger version
ID:	647689   Click image for larger version
ID:	647690   Click image for larger version
ID:	647691   Click image for larger version
Old 02-18-2025, 05:26 PM
dataway's Avatar
And the finished product.
ID:	647694   Click image for larger version
ID:	647695   Click image for larger version
Old 02-18-2025, 05:39 PM
Shiny Shiny is online now
You're good!
Old 02-18-2025, 08:18 PM
Block them ends. I think.
Old 02-18-2025, 08:34 PM
dataway's Avatar
HIS, you know, I put some thought into that. But, so far it seems the flow through the brushes is quite low, so I think I need those ends open to pull the dust into the center to be sucked up by the hose.
I do need to at least tape them up as an experiment and see if it works better that way.
Old 02-19-2025, 08:31 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I asked my wife what vacuuming is? I don't understand why she hit me........
To laugh at men of sense is the privilege of fools.
The Following 2 Users Say Thank You to Heybuck For This Useful Post:
Old 02-19-2025, 01:23 PM
dataway's Avatar
Took the left over "strip brush" and made a little detailing brush.
